Being I shot the ends with Raptor I decided to use 1/8 Plywood sprayed with Raptor instead of FRP panels. My thinking was it would match better and would allow me to "snap" the panels into place, they are also very light.
Scott this looks really good, I might do the same someday. I know 1/8" lauan doesn't do well with water leaks, but I'd rather replace a ceiling panel instead of the floor.Being I shot the ends with Raptor I decided to use 1/8 Plywood sprayed with Raptor instead of FRP panels. My thinking was it would match better and would allow me to "snap" the panels into place, they are also very light.
Which stuff? I'm not seeing anything; Coroplast or something?See if you can find this stuff. Has an R3 insulation value. I got it from Menards in 4X10ft sheets. Glued Hull Liner to it. JWIT
Unfortunately with the high cost of Raptor I painted the top side and Raptor on the bottom or interior side, I thought about the sheets Larry suggested, a friend of mine at a sign shop suggested that material also, in the end I just decided to go with wood.Ah - now I understand the Raptor (bed liner spray) on 1/8" wood panels - to protect upper side from moisture.
Scott, the 6" was not a memory foam type mattress. Can't think of a word to describe the type of foam. It was typical of the foams we use to see in the 90's before the Memory came out. It was comfortable until age (and our waist line) got our buts bumping the plywood base under it. When I built the support under the bed, I built it to only a couple of inches higher than the water tank on the passenger side and the Onan on the driver side. I put the base under the mattress at 21" off of the floor. The math says that the 8" mattress should be at 30" but the tape measure says 29".Larry, was that 6" a memory foam? I would like to take it down to that 29" you stated but that would mean a 6" instead of an 8" Currently by bed platform is 23" from floor, 12" mattress top is 35" from floor.
Thanks for the info, I think the newer memory foam is firmer than the old foam, I will think about a 6" but sounds like 8" would be the safe bet.Scott, the 6" was not a memory foam type mattress. Can't think of a word to describe the type of foam. It was typical of the foams we use to see in the 90's before the Memory came out. It was comfortable until age (and our waist line) got our buts bumping the plywood base under it. When I built the support under the bed, I built it to only a couple of inches higher than the water tank on the passenger side and the Onan on the driver side. I put the base under the mattress at 21" off of the floor. The math says that the 8" mattress should be at 30" but the tape measure says 29".
