The Ferrigno Family's 1976 Palm Beach
I've been wondering if transmission line pressure is something we should start monitoring.
Our transmissions are getting old and leaky inside. If the transmission pump can't keep the line pressure up, then the "clamp" on the clutch packs is going to drop and the clutches will start to slip amongst other problems.
When I had the engine rebuilt, I also had a rebuilt transmission installed. It had random issues with shifting from 1st to 2nd. After 10 years, it finally was not shifting most of the time, yet I could shift it manually. So I took it in for a rebuild, and it operated the same way on the first test drive. The line pressures were low, yet they could not find an issue. So another core was used for a rebuild and installed. Its been fine for the past 4 years, knock on wood.
Just a pressure sensor wired to my EBL would allow me to see the transmission line pressure and maybe warn of a problem before it happens on the road.
I like seeing my tranny temp now….
Funny you mention that, it's on my to-do list to shop for a temp/pressure sensor so I can try to kill two birds with one stone. It's an easy add-on with Winlog for sure.
But, line pressure did check out on this one unfortunately. So the direct clutch itself is certainly shot.
I have a pan sensor in my Ragusa pan running an analog gauge. I also have a DigiPanel so I attached the sensor to the tranny output line to the cooler. I figure I can watch the hottest fluid at that location on the DigiPanel.
If I get around to adding a pressure sensor, I'll put that into the EBL.
Well I've let things get pretty out of date again, so let's catch up.
I think I neglected to mention before, I'd noticed some holes in the wheel well when I was fooling with the water heater. Since it was winter time, I figured I'd patch them up with several layers of woven mat.
I was trying to figure out where all the HDMI cables go at some point. I pried up the base of the cabinet above the sink and found there are three cables, going to an HDMI splitter that seems to not function. So it's one input and two outputs. One output cable goes to the rear bedroom, and the other goes to the TV mounted at the bunk. That makes sense. But the input cable is a mystery! I can't figure out where it comes from. It'd be great if it went to the head unit in the dash since it had DVD, but I don't think that model has an HDMI output. Hmm...this mystery will plague me.
I did a little more work on the Onan board. Made some progress, but we're not quite out of the woods yet. I've not had time to really get back to that. The board now bench-tests correctly, so that's great. The generator itself still dies unless you jump pins 9 and 5. So the board isn't seeing something it wants. I haven't taken time to look at it yet--just spent 5 minutes hooking it up to see what it would do.
I bought the GMC a new companion in January! Our July 4th campout is the deadline for having both ready to go and playing nice with each other. Of course the old blue boat matched the blue Glenbrook, so that just won't work with the Palm Beach. Gotta keep things coordinated now...(actually it was all dumb luck both times). Upgrades included on this boat include: bigger engine (SBC 350), hydraulic power steering, tandem axles, trailer brakes, open bow for more seating, two extra feet, and lots of other doodads. Hopefully it'll be at the lake soon with the GMC!
Time to unbox fuel pump #2, and start getting the aux tank fixed up.
Carnage pics from the trans and diff. PSA: keep up with those oil changes. That final drive was gunky! Pinion bearing was trashed too. Trans looked decent inside, but obviously something let loose inside. Fluid still looked very nice, but there was a lot of clutch material in the pan. Interesting that we somehow destroyed the clutches without burning the fluid.
I had to take a gander at the new pinion before boxing it up with the old diff and sending everything off to Jeff Ianatello for an LSD and gear change.
More tank prep--fixing up the leaky vent nipples with some brazing. I really need a lot of practice at this. I'm pretty bad at setting up a torch and knowing what it needs.
I've been trying to make the shop more usable along the way, so I started an insulation project. I ended up having the ladder feet slide out from under me as I tried to transition from the work platform to the ladder. I fell right off the platform, probably 10+ feet, landed flat on the concrete and the GMC tank. Whoops! My hip put a pretty good dent in the tank, which isn't easy. My fuel capacity is probably closer to 48 gallons instead of 50 now. Oh well.
The fall definitely slowed me down for a few weeks. EVERYTHING hurt since I landed right on my side and clobbered everything on that half of my body. But spreading it all out kept anything from breaking I guess, so here we are.
I finally got the final drive back from Jeff. It wasn't packed as securely as when it was sent out, and it definitely jostled around and created a lot of debris on it's return trip. It had all new seals, and the necessary new bearings, along with 3.70 gears and a limited slip. I'm pretty excited about that. Turnaround time took 41 days instead of the 10 that was quoted. It is a one-man show and he did encounter some bad bearings new-in-the-box, so that lost us a few days. Still, it definitely hurt my camping schedule. We were supposed to be camping on April 10th, and the final drive showed up at 1900 hrs on that day. So I set about getting it installed ASAP. It was a late night, but we got it done. I did some early morning break-in/test drives.
Then we packed up and headed out as quickly as we could to salvage as much of our camping trip as possible. There were several other families expecting us, and we made it!
Still way behind, trying to keep up with the updates--but I just keep working on the dang thing!
So a year ago, our city water fill sprung a leak, flooded the flooring, and was bypassed. I replaced the tee where it taps in with a regular coupler. This left the city water hose connection unterminated behind the cabinets, but of course I knew not to use it, so I could remedy that issue "later". Well, not soon enough! The wife wanted to help prep for the last camping trip and ended up flooding the RV again. Doh! Despite clear verbal instructions, the hose ended up in the wrong spot. I guess that's on me for making it possible, so I decided to whip up a little plug for that to quell any temptations to repeat this error. If anyone wants the 3D printing file, let me know.
My daughter's 10th birthday rolled around, and there was going to be an elaborate sleepover. The boy and I decided we should get out of Dodge, so we did. Just a night away, boondocking and exploring nearby. He got to try out a .22 pellet rifle and now has a new addiction.
I've got a couple hundred miles on the new 3.70 gears at this point, and they were still noisier than I'd anticipated. The drive side had improved notably, but the coast side still whined a lot when you let off the gas. I just had to pull the cover and see how they were breaking in. Looking better than I'd expected. They're not getting hot, chipping, or grinding. It just looks like there's still the slightest of machining texture left, and it's still working on polishing it away.
The drive side is more toward the heel than I'd like, but that's the quiet side, so maybe it'll be OK. There's not much I can do about it now. It was actually a lot quieter on both sides when I replaced the oil with Valvoline full synthetic. I suppose time will tell, but I'm getting less nervous about it as the miles accumulate.
Our big summer-kick-off camping trip to the lake was coming up. We've never managed to use the Palm Beach for this trip, though this will be the 3rd year trying. We've always fallen back to the trusty old Glenbrook. Time to service the Onan since there are no hookups.
Reactions: Carl Stouffer
I've been running the Palm Beach without a fan shroud since the engine swap. It's only really been driving in cooler weather, so it was fine. But with boat towing and hot weather on the horizon, it was time to fix up the old busted fan shroud. The steel wire stitching had served me well before the engine swap, but I really hated the horse-collar setup with a passion. All those brackets had been omitted from the engine install, and I had sworn "never again" when I was dealing with it the last time.
I fixed the cracks, replaced the broken-off mounting ear, added a fiberglass fan-collar, cut the whole thing in two, then added mounting flanges. It fits pretty good, and is pretty lightweight. I'm happy enough.
Due to the front collision damage, we had to tweak the radiator frame a little more to get the rim of the shroud to clear the front of the hatch frame. We used a porta-power to get things back into alignment. This will be a nice upgrade over the years.
Hi Paul - can you elaborate on your cold air intake setup? Parts sourcing, etc. I'm interested in doing the same. Thank you.
Reactions: EricS
It's a Spectre setup, I can't recall the part numbers. It's their low-profile aluminum plenum though. The hose and filter are Spectre for now as well, though I want to switch over to a Silverado HD air filter box at some point. I'm debating running the hose out the driver's side over the valve cover too, if I can keep it from messing up my hatch/console plans. I'll be looking at that tonight. It's currently a very tight fit with the radiator hose, belts, hatch, shroud.
Reactions: Seeburg220
Thank you, Paul. I will look into that. Have a good weekend!
Take a look at the carb hat from TorqStorm. It sits lower and doesn't need an adapter or spacer. Looks good too!
Looking it up, the TorqStorm is claming 3.25" height. Pretty decent, but the low-profile Spectre is 2.4", surprisingly enough.
My setup is tall because I'm using the 454/4-barrel adapter underneath my TBI. I don't like the harsh transition of an adapter plate, so that's where I'm at. Seat-of-the-pants tells me it's awesome! :cool: I'll never put it on a dyno for comparisons, so that's the best "data" I'll get. I also have the option of pumping coolant through the base of the TBI like they did from the factory on the 454 trucks. If I get bored in the winter maybe I'll monitor those temps.
Reactions: EricS
So, we got a "new" boat in January. The old blue and white boat went OK with the 2-tone blue Glenbrook, so I needed to color match the new motorhome too, right? That's sensible, yes?
Well, actually this was just dumb luck I fell into. We'd been looking for a slightly bigger engine, a little more seating, an open bow, power steering, a tandem axle trailer, (the old one was pushing the limits of a single axle), a better swim deck, etc. Well I found everything we wanted and more, in the form of a 1991 Mariah 2000Z. A fantastic brand with a great build quality from years gone by. Complete with a Chevy 350. But it had rusty wheels, rotted tires, rusty surge brake hydraulics, and a knocking in the outdrive. I got it for a decent price and started fixing it up.
The biggest problem--I can't buy new tires for rusty wheels, so what wheels do I get? I started shopping for Ranger/Wrangler/Explorer wheels and such. I figured some aluminum American Racing wheels with the 12-hole pattern wouldn't clash too bad, but in 3 months I couldn't find a decent deal (I'm on FB Marketplace constantly too). Then, another stroke of dumb luck! It turns out for a certain number of years, Ford sourced Alcoa wheels for their Ranger FX4 Pro 2 or something like that. I never knew they existed, and there was a set for $50 stinking bucks less than an hour for me. SOLD!
They both need a good buffing, but I'm pretty pleased with how well they look together!
So we went on our boating/camping trip. All-in-all, it went pretty well. The Onan started up great and made no power (some quick troubleshooting revealed a wire had fallen off the brush block terminals). With that fixed, we had AC, a new microwave (that made a terrible grinding noise until disassembly revealed the fan rubbed after the unit warmed up for a couple minutes). More good news, on the drive down we discovered that the fan clutch is way too over-active now (I'll explain why that's good news further down). Bad news is, the transmission pan is leaking like a sieve and the blackwater had a very slow drip once the tank got kinda full.
Needing to constantly check the trans exacerbated a long-time annoyance. My hatch hits my seats. I don't know why. Other people's hatches don't hit their factory seats. I checked the aluminum frame members under the seat pedestals, and they are still using their original holes. Maybe repeatability was an issue in the factory? Anyhow, the thing is stupidly heavy--1" plywood, with a steel plate across the middle, and super heavy flooring with gobs and gobs of caulk. It's noisy too, with the temporary "console" covering the carb hat hole. So something has to give.
Now for the good news of the bad fan clutch...
It's an excuse to experience the convenience of my new custom fan shroud! I had that fan on and off in record time. It was a downright pleasure! I popped in an old spare clutch. We'll see how it does--maybe I'll have to order a new one again. At least they're easy to change now!
Reactions: dsmithy and Bhart
Good point, but the advantage of the TorqStorm is that the intake hose will clear the valve cover. It appears the Spectre must be indexed so that the hose goes around the valve cover? I tried a few different hats, even the factory air cleaner, and they all needed a spacer to fit over the injectors. BTW, I have the aluminum moho intake manifold and the adapter lines up fairly well, but not nearly as efficient as yours! Nice work!
I'm pretty sure it clears the valve cover. I aimed it forward as much as I could so I could minimize the width of the hatch cutout. I believe someone else is running this hat at the 9:00 position, but I can't remember who. I actually almost rerouted mine a couple days ago, but chickened out due to the hatch cutout issue. The 11:00 position BARELY works out. The floor, shroud, radiator hose, air intake hose, engine brackets and engine belts are really crammed together. It's hard to ensure things don't rub the intake hose.
A couple drawbacks to this one, it resonates and functions as an injector amplifier. Almost comically loud--I'm going to toy with damping it directly. It also won't clear a quadrajet acceleration pump arm without some custom grinding/clearancing. That seems like an oversight, but no longer an issue for me. It's also expensive for what it is, if you ask me. I just had trouble finding a Jeep hat near me.
Reactions: EricS
I splurged on a Ragusa step, transmission pan, and triple battery tray. I'm pretty disappointed in the quality, but have lodged those complaints in another thread . I've got the step and pan installed for now (after some customizing), time will tell if I pursue replacements. I'm a bit miffed by what I ended up with.
I dug the T-skirts out of storage and did a little repair to them. Then I remounted them with stainless piano hinge (old mounting holes were a little worn out on the motorhome body too). My macerator outlet is now hidden behind the port-side T-skirt, which I'm liking.
Speaking of blackwater, I had to address "the drip" from the previous camping trip. There was a hairline crack in the original weld. I was somewhat relieved it wasn't my extensive repairs that had gone bad. I ground it out a little and laid a new bead of PP weld in the gap. Time will tell if it's water tight once more.
This guy absolutely LOVES being in the motorhome. He simply won't allow me to work in there alone. As stubborn as huskies are, it's easiest to just give him what he wants. :)
I printed a tablet holder and the fit is really nice. I just need to print a mount for the holder, and figure out where to mount it.
I'm allowing myself to tackle a few of the little things have have been bugging me, line the incessant rattling of the stove while underway. I recently realized the legs of the grates were supposed to have little feet. There were some missing, and others mismatched. I did a lot of searching for black silicone vacuum caps that were ~3/16, and the only place I could find them was AliExpress.
Next up is building a new engine hatch. I'm tired of the heavy, loud, cumbersome original. I want it to swing up while clearing the seats, stay up by itself, be quieter, transfer less heat, be easier to remove and set down somewhere, easier to latch/unlatch. I started with a 1/2" sheet of plywood, and made a 2.5" raised center for it. This stiffens it a bit, gives the console a raised platform to sit on, and clears the carb hat underneath. Gravity clamps were employed for mounting the raised center.
I was glad to see I can swing the seats around. I'd thought the passenger seat was hitting the console, but it's actually limited by the dinette bench first. Huh.
The console is from a early 2010s Caravan/Routan/Town&Country, and is the "premium" option. It's one of the things I liked best about the Routan van we had. It has a power outlet built in, and a quick-release mounting base with built-in contacts for the power. I got it from the yard with a pigtail included, so I'll have to wire that up for convenience at some point.
I'm really loving the new latches. They were a bit fiddly to install. I had to polish the latches and bevel the catches. But after that, and a good soaking with a dry-lube, they're butter smooth! It is so quick and easy to lift or lower the hatch now. I'll be more prone to checking things with greater regularity. It's all about removing those little barriers.
Up next is some sound deadening and some carpet or something. We'll see. I didn't like the sloppily installed/caulked-up and heavy laminate though.
I cant tell you how well its going to work, but re: the sound deadening project, I'm using a combination of KilMat (the heavy butyl rubber stuff backed with foil) and something I found by DEI that is used under carpeting.
It should be an effective solution. The KilMat is heavy, but it quells those large panel resonances so well I believe the weight penalty will be worth it. I did my whole cockpit and I'm also lining the rear wheel "tubs" as they rattle like crazy when you tap them.
We took the motorhome to White River Falls and the Wasco County Fair this summer, right after my last posts. I'd swapped my steering wheel for better gauge visibility, and I really like it! It was hard to pay $100 for something that seemed like a $10 junkyard find 20 years ago, but here we are. All things considered, I probably got a good deal for it. Came from ebay in Canada, I believe on a '78 G30.
The fair is VERY rural, and very old fashioned, located at the edge of the Warm Springs Indian Reservation. No fancy rides and lights--just lots of country kids having good old-fashioned fun. There are a lot of events with the local native tribes too, and my daughter got to learn some native dances with a boy about her age. Both fun and adorable. We got to enjoy a rodeo and a demolition derby while we were there too.
Since then, I've been mostly focused on getting the old Glenbrook ready for sale, so the Palm Beach didn't get any attention until this week (aside from some other camping trips).
I finally rearranged the electrical cabinet to my liking. There was a ton of wasted space, and no room for my Xantrex inverter/converter. Now I have room for it, a possible transfer switch install, and a solar controller. I'm much happier with this arrangement. I got rid of the extra divider/wall in the middle of the cabinet where the breaker box was mounted, changed the shore cord from rear entry to side entry, relocated the breaker box and outlet/switch box to the rear wall, and moved my 12V fuses upward a bit. Much better. I'm still considering mounting the remote controller somewhere visible, but I'm not sold on the idea.
I keep a decent amount of 1/0 welding cable on hand for such projects. I also buy these 1/0 terminal lugs that only have 1/4" holes, but they leave all the "meat" on the ring terminal end. So there's plenty of material left to drill out to the desired size. This reduces the amount of unique parts I have to have on hand. I think I used 1/4", 5/16" and 3/8" as needed on this particular install. They come with adhesive lined heat shrink too--both red and black.
I finally decided to install my Toyota/Koito headlight upgrade after having it on the shelf for a couple years. That's a nice kit! Beam pattern and brightness is much improved on the dark, rainy, curvy highways.
I also decided to tackle the HVAC blower. All four speeds were "low". No change at all. It turns out, my fan switch was 99% unplugged. I lubed the controls up a bit too while I was at it. While I was troubleshooting wiring, I got the PO's LED strip light install straightened out. It's a little silly/unecessary, but all in good fun. You can pick any color you choose with a remote, so it does make for some decent ambiance. Might as well try out the coach's official turquoise accent color...
The reason I got a burr under my saddle for the recent upgrades/fixes was that I was tasked with hauling around a bunch of high schoolers. We had about 60 kids from the local youth group doing an around-the-town scavenger hunt/challenge. They were all allowed to sign up to ride with whichever driver/vehicle they wanted, and I ended up with a full dozen kids! Made 15-20 stops over the course of an hour, with all the kids piling in and out. Had a well stocked fridge and freezer, music and lights. Good times. The responses were very favorable, so I think we'll be doing this annually. :)
I guess I never added, the Palm Beach's services were requested by the youth group once more. I guess it was a big hit for the pre-Thanksgiving scavenger hunt, so we got roped into the local Christmas parade too. The kids wanted to have a float, so we towed a flatbed for them. Then it was back into the carport for its winter slumber--but not without cracking the corner of the rooftop storage box. :cautious: I got complacent with clearances since it was never an issue with the Glenbrook (the previous resident of the carport). Anyway, that closes out 2025.
The Palm Beach just sat there from January to May. Winter was mild, but we still didn't use it.
I don't have the Electrolevel II system working right yet, and I have to do manual airbag filling with a shrader valve. Because of the rooftop cargo box interference with the carport, and the driveway angle leading to the carport, it's a whole procedure to get the coach in and out. I have to air the bags up to keep the tail end clear of the ground, back up until the box almost hits the carport, then let the bags out till it clears. Pulling out, I have to put just enough air in the bags to pull forward until the box clears the carport roof, then fully fill the bags so the tail end stays off the ground as I pull up onto the main driveway. Such a hassle, since I don't have a compressed air source over there.
Because of this, I'm motivated to get the air system working now. I also need to raise the carport, but that might wait a little while if I can get the air system going. There's a cheap Amazon/China brand compressor in the cabinet right now, wired to a cigarette lighter outlet with an undersized ground. It would max out at about 50 psi, which is when I think it reached equilibrium between compressor output and leakage rate. I fixed a few leaks, and got it up to 75 psi. Almost enough to lift the coach off its resting blocks, but not quite. I seem to get a lot of leakage by the leveling valve and its associated fittings/adapters. I took them apart and tried putting some new o-rings in, but it didn't seem to change anything. Hmm. I'll have to get more serious about that later, it was time to go camping!
I did manage to get the period-correct-ish mercury thermostat installed before our first trip of the year. That was pretty simple, and I love having an "off" switch for <50F now. The old one would run all winter unless you pulled the fuse.
I've been largely trying to keep this coach out of the rain, but the day will come when I have to start making it more precipitation compatible. I've been hoping to get the new full-height sliding side windows, and do the body damage repairs and mirror upgrades at the same time. I don't think it's going to work out since Applied still doesn't have those in-hand a couple years later. So I've got a power/heated Freightliner mirror on the way, and it's about time to tackle this body damage. If I like the results, I'll buy another mirror for the other side.
Right before the trip, I did install a "new" Fantastic vent fan with a Max Air vent cover in the back bedroom. The original vent cover was cracked in half, allowing some water damage and mold when in the auction yard three winters ago. I've still gotta address the soft subfloor there, but we mostly keep the settee in bed mode anyway. I had to cut the roof since the corners of the old vent were rounded on a rather large radius. It probably took 5-6 hours since the "new" vent fan was actually used. And with a vinyl frame, I couldn't be mechanically aggressive with removing the layers of old sealants. It was a nasty job, but the vent was free from a friend and has all the bells and whistles. I think retail with the rain cover is $430 or so these days? I have another one that he gave me, but I'm even less motivated to put it in now. But with that, we were off for the first trip of the year!
It was a coast trip, so there were some rain showers. A previously dry area developed a waterfall. Eternabond tape didn't help, but thankfully the rain didn't last forever. I think I'll have to reseal my caps and rails sooner rather than later. Overall the coach did very well for just being pulled out of winter storage and put on the road. I even had a few minutes to kick my feet up.
Reactions: dsmithy and Kendra
After the coast trip, I needed to prep for a car show for my wife's 1948 Pontiac. Then I needed to prep for a trip to the Redwoods with the family.
I noticed the house batteries had become a house themselves. I guess I need to add a screen to the louvers in the hatch!
I'm still paranoid about the front diff whine, though it is lessening over time. So I changed the oil again, and decided to make a magnetic fill plug. I bored a hole in the end of the original plug, and JB Welded an 8mm x 8mm cylindrical magnet into it. I let the oil I drained off settle for a couple days so I could look for sparkles. I poured the oil off the top, and sure enough it was a bit sparkly. None of the glitter could be felt between my fingers though--it has no grit feel to it. So there's nothing terribly alarming yet. If the diff was slowly getting louder instead of slowly getting quieter, I'd be a little more worried.
I recalled from last summer that my fan clutch was over-active--two of them were, actually. You'd have to coast downhill for at least a minute on a cool day to get it to ever shut off. And the engine temp would always be rock-steady. There never seemed to be good cause for the fan to come on that much. Rather than getting a third clutch to do the same thing, I decided to attempt recalibrating one of the ones I had. I cut a new indexing slot for the bi-metallic coil. Go clockwise to engage later, counter clockwise to engage sooner (for this one anyway). It worked! I think I should've gone a bit farther, but the fan definitely runs a lot less.
One thing is for sure, I really love my fan shroud. I would've never messed with the clutch for the purpose of experimental calibration with the horse collar setup before.
On the coast trip, the wife noted that the license plate light wasn't working. Not yet knowing the itinerary for the next trip, I thought I should look into it. Well, I think it was pretty self explanatory! Yikes! The ground terminal for the housing wasn't even there anymore--completely detached. I'd kinda thought that the lens arrangement always looked funky on this one, and we eventually figured out why. The lens is much smaller than the body opening. There is a plastic adapter plate that goes over the large hole, then the lens mounts to the plate. Someone had reversed the order of assembly on these parts, and tried to use the flat adapter plate as a retaining ring over the bulging lens! It was warped like crazy, and even cracking. We had to flatten it out with hot air as best we could.
Since we were leaving the next day, I decided to improvise something "temporary". I had some warm white 12V LED strip, some plumber's tape, and some zip ties. The result is a license plate light that looks good from the outside. What's on the inside doesn't count. :D
I was getting sick of mopping up ATF from the power steering every time we had this thing on the lift, so I finally tackled the leaking pressure line coming from the pump. I didn't want to order something proprietary and wait on it, so I just got a universal 18" hose made with 3/8" inverted flare at my local tractor/auto parts store. Then I made a metal line to go with it--I think it took 8 bends to keep it tidy and out of the way.
Note: On the steering gear end, you need the special 11/16" tube nut for the 3/8" line instead of the standard 5/8" tube nut for 3/8" line. Luckily I was able to reuse my old one by cutting it off the old leaky assembly, as I did not have another one on hand.
I'd finally tried to install the new awning head I bought, and it is definitely not compatible. I bought the "contour" series from the correct era, but Zip Dee says "Oh, you need the 'short contour' head". Nothing noted in their IPB about this difference, and no measurements provided on their site.
:rolleyes:
