Now I'm torn; I was going to install my transfer switch into the shore-power/water cubby on the backside of the breaker box, with a short run of 6/4 into that box and 6/3 from the 4KW inverter (wired like the Onan outlet). But if I move things around like Paul (pvfjr) did, I might have enough room to put the switch in the cabinet, simplifying routing the 6/3 from the inverter (currently living under the rear bed with the batteries). I may have to purchase the upgrade breaker box/12v fuse panel (same as used by Kendra) to test fitment with the transfer switch.
(picture "borrowed" from Paul's post for reference)
Or, give up on the Onan, remove it, move batteries and inverter to that location, and leave the electrical panel as is for now; no transfer switch.....
I'm torn.....
I'm torn.....
