Successful test! Battery down by 10% overnight running fridge and freezer only. Charged fully by 10AM even under overcast sky. Now, an inverter...
Indeed. The purpose of this inverter will be to run the heat pump, microwave, and perhaps an induction cooktop. That is the reason for remote on/off capability. Most everything else runs from DC. Small draws probably won't even activate the inverter.When sizing an inverter, remember the bigger the inverter, the higher the standby power consumption is. If you are running something like a heat pump and need the power for that, you may want to consider a much smaller one for the TV, charging cell phones, CPAC etc. to save power when the heat pump is not being used.
I seem to be of the school that thinks; "sure, I can throw money at it and get the best solution with the least headaches, but I want to see what I can get working on the low-end with much brain-cell burning..." I LIKE projects. I LIKE to customize... I own a GMC Motorhome...Yeeeouch. I'm glad I converted shore power to solar as well, but this involves a surprising number of things to piece together and adjust.
Let me know what you think about your transfer switch once you get it in. I always thought the buzz-box in my Glenbrook was the old power converter. But once I installed my Xantrex converter/inverter, the buzzing didn't go away. It turned out to be the transfer switch all along! Just a constant hum--mildly annoying. I'm still using the generator outlet/plug combo on my Palm Beach, until I can figure out something better that doesn't break the bank.Time to complete the solar integration.
In about a week I should have the inverter connected to the house breaker panel via the transfer switch. Then I should be able to forget about the solar systems entirely and get back to fabricating ceiling and wall panels. At some point I will replace the old breaker panel and DC fuse block with a combination panel.
- 30 amp automatic transfer switch purchased.
- 10/3 stranded "romex" purchased.
- Battery tie-down straps ordered.
- Various circuit-breakers for the solar system obtained (installing tomorrow).
Maybe I can get started on the solar installation next month if the hurricanes stay away. I have just completed the 70 gal alum gas tank, fuel delivery system and FiTech installation on my coach. I detailed it on So what did you do to your GMC today?View attachment 14732
This is the solar array on my 26 foot coach. I also have the base drawing.
My rig with the toad.
This is a (15) panel SunPower semi flexible solar system applied directly to the roof with zero framing. Check out how to install this on https://www.gmcmotorhome.org/thread...-batteries-and-sailor-mans-lifepo4-build.982/
I have the drawings on my cadd system, including elevations, floor plans, sections, elevations, etc. You can copy any of my drawings on the thread.
Will do! Just waiting on the return of the 30A to complete before ordering the 50A (too many returns bouncing back and forth; letting everything catch-up).Let me know what you think about your transfer switch once you get it in. I always thought the buzz-box in my Glenbrook was the old power converter. But once I installed my Xantrex converter/inverter, the buzzing didn't go away. It turned out to be the transfer switch all along! Just a constant hum--mildly annoying. I'm still using the generator outlet/plug combo on my Palm Beach, until I can figure out something better that doesn't break the bank.
I have bought a system from Tadi Brothers, but I am not ready to do the installation.Success!
The 360° bird's eye view camera system is functional!
Rear view (no big deal by itself), front view, and both sides. Integrated into an overview and virtual 3D view. Also allows for showing just the combined left and right views (split-screen) going down the road to keep the vehicle between the lines. Of course, the representational vehicle isn't a GMC motorhome (there isn't even a van to choose). Someday I may have to try to find a community to customize this system (XDA Developers Forums perhaps?) to allow for custom graphics and measurements; the inexpensive system I picked as a test isn't intended for vehicles 26' long. There is still some tweaking to do (too much of the side of the coach is visible in the side cameras, one of the side cameras is reversed, etc.), but the firmware has provisions to customize the camera views. This was simply a proof of concept. The cameras were taped to the body. Once the weather warms-up, I will drill holes and affix them permanently, then spend time fine-tuning the views.
The basic "kit" was $135, plus $100 ($50 each) for two wider-angle cameras with more flexible mounting options than the cameras that came with the kit, and $30 for the calibration mats (I'll loan those to anyone in the nearby area who wants to install a system). Added cost would be for your choice of monitor ($25-$50 for a 4" or 5" display; more for larger). I plan to use the rear camera input of my dash-top Android Auto system (shown below). If you already have an input on an existing camera system or dedicated GPS device, then you have a monitor. This system supports standard NTSC/VBS/composite video, AHD (720p/1080p), VGA, HDMI, etc. The cameras are AHD 1080p/25hz.
If you wish to avoid some of the headaches I experienced configuring a system intended for a car onto a motorhome, there are more expensive systems that are turn-key for larger vehicles. Much more expensive!
View attachment 12687View attachment 12688
