wandering
fernand levesque
6
HI everyone ! I have a1974 painted dessert since i bought my coach 8 years ago I did acomplete frame off restauration new,new,new,caspro complete kit,sway bars front rear,steering box,shocks,bearings,front rear,last week new b.f.goodritch tires sterring shaft new front end complete 4 ball joint dave linzey idler arm relay arm name it i did it.I SEEN ON ONE OF YOUR E-MAIL SOMEONE PUT 100 P.S.I.IN THE AIR BAG this got me thinking I have shut off valves on the air bags.So I check the air pressure it was only 67 p.s.i so i close both valve and put 95 psi in both air bag this made more improvement than anyyhing else NOW BY BROBLEM IS THE BACK OF THE COACH IS TOO HIGH.ANYONE HAVE A ANSWER THANKS FERN LEVESQUE IN CANADA
_________________________________________________________________
New: Messenger sign-in on the MSN homepage
http://go.microsoft.com/?linkid=9677403
Fern-
We visited your coach in Harrington and it is an incredible restoration,
exterior and interior. I hope that you might decide to write some
articles about what you did with the macerator, the generator, and
numerous other devices. There are pictures of your coach published on
the GMCMI Site under the Harrington Rally.
My suggestion on the air bags is to try various pressures until you
reach a satisfactory level that is not so high (maybe 85-90 lbs.), then
readjust your levelers to that height. Mine also wonders, and higher
pressure helps, but does not cure the problem. You may have to convert
to a four-bag or quad-bag system to get the control and ride that you
desire.
Hope to see you and you bride at another rally soon--maybe the Eastern
States Rally at Elkhart Indiana this October.
Bestwishes-
Jim "Doc" White
Wintergreen, VA
75 GMC GB Stretch
> List Information and Subscription Options:
> http://temp.gmcnet.org/cgi-bin/mailman/listinfo/gmclist
Fern, I too have been chasing a wandering coach. When I purchased i=
t about 5 years ago it had a bad engine so I decided to pull the front clip=
and do a complete rebuild. As you did, I rebuilt or replaced everything! I=
?ve been chasing a wandering problem the whole time. I?ve tried=
everything, different tires, another new steering box, every alignment spe=
c known to man, heavy sway bars front and rear, ect. Some of the things mad=
e a small improvement some did nothing. Returning from a trip last year I t=
hought I heard a clicking noise that may be coming from a front axle. Pulle=
d them out and had them rebuilt for the second time. After reinstalling the=
axles and while I had the front end jacked up I decided to start it and pu=
t it in gear to see if I could see anything amiss. My dad was in the GMC an=
d started it and put it in gear while I very carefully looked under the fro=
nt end, he turned the wheels back and forth and I saw nothing, then I told =
him to shut it down and when he hit the brakes, WOW. The lower control arms=
shifted from the torque of the spinning wheels and the tires toed in at le=
ast an inch. I could see a lot of movement in the lower control arm bushing=
s which I had replaced at the rebuild only about 5,000 miles earlier. I rem=
embered ordering them from my local Autozone and specifically asking for Mo=
og brand, when the came they were in a different box, but they assured me t=
hat they were made by Moog, and only boxed for a different company. I insta=
lled them and never thought about them again until I saw how much give the =
rubber had. I ordered neoprene bushings from Jim K, and that has made the b=
iggest improvement in handling of anything I have done. While chasing my wa=
ndering problem, I had gone to offset Moogs in the top to get more caster a=
nd am trying to decide whether to change them also. Evidently the lower one=
s I installed were too soft for the weight of the GMC. Moogs? I don?t=
know, but they were defiantly allowing a lot of movement. I too thought my=
problem must be in the rear since everything in the front was new. Just so=
mething to think about, and I hope that you too can someday relax when that=
18 wheeler sneaks up from the rear! Mike (tired of messing with the f=
ront end) Morton
If you do not start with the A frame gromets, your wasting your time.
There are the easy way to do it and the hard way. Most call me for advice.
> Fern,
> I too have been chasing a wandering coach. When I purchased it about 5
> years ago it had a bad engine so I decided to pull the front clip and do a
> complete rebuild. As you did, I rebuilt or replaced everything! I?ve
> everything, different tires, another new steering box, every alignment spec
> known to man, heavy sway bars front and rear, ect. Some of the things made a
> thought I heard a clicking noise that may be coming from a front axle.
> Pulled them out and had them rebuilt for the second time. After reinstalling
> the axles and while I had the front end jacked up I decided to start it and
> put it in gear to see if I could see anything amiss. My dad was in the GMC
> and started it and put it in gear while I very carefully looked under the
> front end, he turned the wheels back and forth and I saw nothing, then I
> told him to shut it down and when
> he hit the brakes, WOW. The lower control arms shifted from the torque of
> the spinning wheels and the tires toed in at least an inch. I could see a
> lot of movement in the lower control arm bushings which I had replaced at
> the rebuild only about 5,000 miles earlier. I remembered ordering them from
> my local Autozone and specifically asking for Moog brand, when the came they
> were in a different box, but they assured me that they were made by Moog,
> and only boxed for a different company. I installed them and never thought
> about them again until I saw how much give the rubber had. I ordered
> neoprene bushings from Jim K, and that has made the biggest improvement in
> handling of anything I have done. While chasing my wandering problem, I had
> gone to offset Moogs in the top to get more caster and am trying to decide
> whether to change them also. Evidently the lower ones I installed were too
> soft for the weight of the GMC. Moogs? I don?t know, but they were
> ot of movement. I too thought my problem must be in the rear since
> everything in the front was new. Just something to think about, and I hope
> that you too can someday relax when that 18 wheeler sneaks up from the rear!
> Mike (tired of messing with the front end) Morton
Applied/GMC, Fremont,CA
Fern -
When you re-built the front-end, did you use the offset bushings to get
more caster. From what I've been told, that is the answer to most wandering
problems. When I bought mine a few years ago, the thing wandered all over the
place. After closer inspection of the front-end components it appeared
that everything was a little worn. So, like most owners, I re-built the
front-end with the guidance of Jim K., Dave Lensi, and others to get the right
components. Well, the wander is gone and it wasn't too painful to the wallet
either.
Brian Gleissner
74 Sequoia
Fern,
Bonjour mon ami, comment allez vous?
Try setting the rear ride height at 33 inches as measured from the ground to
the wheel well arch in the middle of the bogies just below the beltline.
Don't worry about the pressure c'est ne pa important!
Rob Mueller
Sydney, Australia
'75 Avion - AUS - The Blue Streak TZE365V100428
'75 Avion - USA - Double Trouble TZE365V100426
'75 Avion - USA - The Parts Coach TZE 365V100324
[mailto:gmclist-bounces] On Behalf Of Fernand Levesque
Sent: Friday, September 04, 2009 2:55 PM
Subject: [GMCnet] wandering
HI Brian ! yes i did replace the bushing with offsets I guess someone is doing some in polyurethane are they offsets Fern
> From: Oldrvguybcg
> Date: Fri, 4 Sep 2009 23:38:01 -0400
> To: gmclist
> Subject: Re: [GMCnet] wandering
> Fern -
> either.
> Brian Gleissner
> 74 Sequoia
New! Open Messenger faster on the MSN homepage
http://go.microsoft.com/?linkid=9677405
Hi Michael thanks for the info I will be checking that today I did replace the four like you say could be too soft thanks FERN
> To: gmclist
> From: memorton
> Date: Fri, 4 Sep 2009 17:53:33 -0500
> Fern,
> I too have been chasing a wandering coach. When I purchased it about 5 years ago it had a bad engine so I decided to pull the front clip and do a complete rebuild. As you did, I rebuilt or replaced everything! I?ve been chasing a wandering problem the whole time. I?ve tried everything, different tires, another new steering box, every alignment spec known to man, heavy sway bars front and rear, ect. Some of the things made a small improvement some did nothing. Returning from a trip last year I thought I heard a clicking noise that may be coming from a front axle. Pulled them out and had them rebuilt for the second time. After reinstalling the axles and while I had the front end jacked up I decided to start it and put it in gear to see if I could see anything amiss. My dad was in the GMC and started it and put it in gear while I very carefully looked under the front end, he turned the wheels back and forth and I saw nothing, then I told him to shut it down and when
> he hit the brakes, WOW. The lower control arms shifted from the torque of the spinning wheels and the tires toed in at least an inch. I could see a lot of movement in the lower control arm bushings which I had replaced at the rebuild only about 5,000 miles earlier. I remembered ordering them from my local Autozone and specifically asking for Moog brand, when the came they were in a different box, but they assured me that they were made by Moog, and only boxed for a different company. I installed them and never thought about them again until I saw how much give the rubber had. I ordered neoprene bushings from Jim K, and that has made the biggest improvement in handling of anything I have done. While chasing my wandering problem, I had gone to offset Moogs in the top to get more caster and am trying to decide whether to change them also. Evidently the lower ones I installed were too soft for the weight of the GMC. Moogs? I don?t know, but they were defiantly allowing a l
> ot of movement. I too thought my problem must be in the rear since everything in the front was new. Just something to think about, and I hope that you too can someday relax when that 18 wheeler sneaks up from the rear!
New! Faster Messenger access on the new MSN homepage
http://go.microsoft.com/?linkid=9677406
HI JIM ! which system is better for the money Quad or the Four bag Thanks for the info FERN.
> Date: Fri, 4 Sep 2009 16:50:53 -0400
> From: jameswwhite
> To: gmclist
> Fern-
> desire.
> Bestwishes-
> Jim "Doc" White
> Wintergreen, VA
> 75 GMC GB Stretch
Fern-
You just opened a GMC version of Pandora's Box! This is a very
controversial subject here on the GMC net and at rallys as well. There
are obviously some advantage to both approaches, which the sellers and
some users will be happy to discuss.
I will be happy to provide a personal opinion off net.
Regards-
Jim "Doc" White
Wintergreen, VA
75 GMC Stretch
>> From: jameswwhite
>> To: gmclist
>> Fern-
>> desire.
>> Bestwishes-
>> Jim "Doc" White
>> Wintergreen, VA
>> 75 GMC GB Stretch
>>> GMCnet mailing list
Fernand,
There are no offset urethane bushings made at this time. Both major
manufacturers in the US have declined because the bushings would turn
in the sleeves. The rubber ones don't becaused they're bonded to the
sleeves.
On Sat, Sep 5, 2009 at 4:18 AM, Fernand
Steve Ferguson
'76 EII
Sierra Vista, AZ
Urethane bushing source
www.bdub.net/ferguson/
For my money I installed the four bag. For myself I would have
installed the quadrabag, but my money wouldn't cooperate!
Larry Davick
The Mystery Machine
Ljdavick at comcast.net
On Sep 5, 2009, at 5:06 AM, Fernand Levesque
>> From: jameswwhite
>> To: gmclist
>> Fern-
>> restoration,
>> then
>> convert
>> desire.
>> Eastern
>> Bestwishes-
>> Jim "Doc" White
>> Wintergreen, VA
>> 75 GMC GB Stretch
>>> LEVESQUE IN CANADA
>>> GMCnet mailing list
Larry;
Would you please tell me what pressure is in your bags when you are at
travel height?
Thanks;
Gordon
> Larry Davick
> The Mystery Machine
I would be happy to, but my coach is in Ohio and I haven't had the
pleasure of driving it yet!
I'll be bringing her home soon and I intend to be a real pest on this
list with questions and comments. I might even post a picture or two.
> Larry;
> travel height?
> Thanks;
> Gordon
>> Larry Davick
>> The Mystery Machine
Since the urathane is not molded to the bushing , the manufacture turned us
down.
You need to stay with thw rubberones.
On Sat, Sep 5, 2009 at 4:18 AM, Fernand Levesque
> > From: Oldrvguybcg
> > To: gmclist
> > Fern -
> wandering
> the
> right
> wallet
> > either.
> > Brian Gleissner
> > 74 Sequoia
Fern,
The 4 Bag is the origional design. It was the first .
The Quadrabag or Q Bag is a 2 1/2 generation after the original.
It rides smoother, yet has a firm control,full up and down,will not
bend,easier to mount and have few inovations to make it worth $4oo more.
On Sat, Sep 5, 2009 at 5:06 AM, Fernand Levesque
> for the info FERN.
> > From: jameswwhite
> > To: gmclist
> > Fern-
> > desire.
> > Bestwishes-
> > Jim "Doc" White
> > Wintergreen, VA
> > 75 GMC GB Stretch
> E-MAIL SOMEONE PUT 100 P.S.I.IN http://p.s.i.in/ THE AIR BAG this got me
> > > GMCnet mailing list
Forget measuring the air pressure. If your leveling system works, use it to set the correct rear ride height.
The shut off valves are only useful for those people who have leveling system failures. If your leveling system is not operational, then you can set the level temporarily with the shutoff valves by measuring the height as per the manual. This height is going to change as you add or remove items from the coach like people, gas, water, luggage, etc. This is why you eventually need to fix the leveling system so it automatically adjusts for these changes.
Air pressure is only an indicator of coach loading and ride height. What you want is the correct ride height. I occasionally over inflate mine to get over a low clearance in the road. Believe me it really screws up the handling on the highway at higher speeds. Occasionally I'll air it up in town and forget to set it back to auto on the road. I notice the difference immediately when I get up to speed. Luckily on a correctly operating system it is just a flip of a switch or turn of a knob to get it to return to normal.
If you look at the castor, camber, and toe-in with a gauges then change the real height you can see, the rear height affects all three alignments. This is why GM designed the system foe auto correction.
I have found that whenever it is wandering allover it is do to something loose.
Roger-
Having just completed front bearings, hubs, knuckles, ball joints, new
rear disks brakes with hubs and bearings, new Eagles wheels, new BFG
tires, where would you look for something loose?
I appreciate you suggestions-
Jim "Doc" White
Wintergreen, VA
75 GMC Stretch
I have not been watching, but are you running ragwalls at 55lb?
gene
On Fri, Sep 18, 2009 at 1:51 PM, Jim White wrote:
> Roger-
> Jim "Doc" White
> Wintergreen, VA
> 75 GMC Stretch
> loose.
Alternator Protection Cable
