Gene-
I just switched from Firestone TA's (ride much like wooden wheels) to
16" BFG All Season Commercial Steel Belted with rag walls. I started at
60 lbs. just last week for testing with air bags at 95 lbs.
What would you suggest?
Doc
> I have not been watching, but are you running ragwalls at 55lb?
> gene
> On Fri, Sep 18, 2009 at 1:51 PM, Jim White wrote:
>> Roger-
>> Having just completed front bearings, hubs, knuckles, ball joints, new
>> rear disks brakes with hubs and bearings, new Eagles wheels, new BFG
>> tires, where would you look for something loose?
>> I appreciate you suggestions-
>> Jim "Doc" White
>> Wintergreen, VA
>> 75 GMC Stretch
>>> If you look at the castor, camber, and toe-in with a gauges then change
>> the real height you can see, the rear height affects all three alignments.
>> This is why GM designed the system foe auto correction.
>>> I have found that whenever it is wandering allover it is do to something
>> loose.
>>> _______________________________________________
>>> GMCnet mailing list
>>> List Information and Subscription Options:
>>> http://temp.gmcnet.org/cgi-bin/mailman/listinfo/gmclist
>> GMCnet mailing list
Doc
> gene
>> Roger-
>> Jim "Doc" White
>> Wintergreen, VA
>> 75 GMC Stretch
>> loose.
>>> GMCnet mailing list
>> GMCnet mailing list
