Fern,
The 4 Bag is the origional design. It was the first .
The Quadrabag or Q Bag is a 2 1/2 generation after the original.
It rides smoother, yet has a firm control,full up and down,will not
bend,easier to mount and have few inovations to make it worth $4oo more.
On Sat, Sep 5, 2009 at 5:06 AM, Fernand Levesque
wrote:
> HI JIM ! which system is better for the money Quad or the Four bag Thanks
> for the info FERN.
> > Date: Fri, 4 Sep 2009 16:50:53 -0400
> > From: jameswwhite
> > To: gmclist
> > Subject: Re: [GMCnet] wandering
> > Fern-
> > We visited your coach in Harrington and it is an incredible restoration,
> > exterior and interior. I hope that you might decide to write some
> > articles about what you did with the macerator, the generator, and
> > numerous other devices. There are pictures of your coach published on
> > the GMCMI Site under the Harrington Rally.
> > My suggestion on the air bags is to try various pressures until you
> > reach a satisfactory level that is not so high (maybe 85-90 lbs.), then
> > readjust your levelers to that height. Mine also wonders, and higher
> > pressure helps, but does not cure the problem. You may have to convert
> > to a four-bag or quad-bag system to get the control and ride that you
> > desire.
> > Hope to see you and you bride at another rally soon--maybe the Eastern
> > States Rally at Elkhart Indiana this October.
> > Bestwishes-
> > Jim "Doc" White
> > Wintergreen, VA
> > 75 GMC GB Stretch
> > > HI everyone ! I have a1974 painted dessert since i bought my coach 8
> years ago I did acomplete frame off restauration new,new,new,caspro complete
> kit,sway bars front rear,steering box,shocks,bearings,front rear,last week
> new b.f.goodritch tires sterring shaft new front end complete 4 ball joint
> dave linzey idler arm relay arm name it i did it.I SEEN ON ONE OF YOUR
> E-MAIL SOMEONE PUT 100 P.S.I.IN http://p.s.i.in/ THE AIR BAG this got me
> thinking I have shut off valves on the air
bags.So I check the air pressure
> it was only 67 p.s.i so i close both valve and put 95 psi in both air bag
> this made more improvement than anyyhing else NOW BY BROBLEM IS THE BACK OF
> THE COACH IS TOO
HIGH.ANYONE HAVE A ANSWER THANKS FERN LEVESQUE IN CANADA
> > > _________________________________________________________________
> > > New: Messenger sign-in on the MSN homepage
http://go.microsoft.com/?linkid=9677403
> > > GMCnet mailing list
> > > List Information and Subscription Options:
http://temp.gmcnet.org/cgi-bin/mailman/listinfo/gmclist
> New! Faster Messenger access on the new MSN homepage
http://go.microsoft.com/?linkid=9677406
Applied/GMC, Fremont,CA
