The flat motors would usually seat the rings in five or six hours - chrome cylinders took substantially longer, and some chromes never seated the
rings. This on the airplane, after a 30 minute initial run - in on a test stand with a test club
fitted. The seating is indicated by a drop in oil
temp. Once they're seated, we told the owners, treat it how you
like. Remember though, the flat motor sees much harder duty in an airplane than the engine in a road
vehicle. It's more analoguous to a boat engine.
'76 23' transmode norris
'76 palm beach
Sent: Tuesday, January 31, 2012 7:53 PM
Subject: Re: [GMCnet] S & J Engines in Spokane, WA
Engines that have been remanufactured generally break in quite quickly. In
my personal experience, they seem to develop more power, in passenger car
usage, after 5000 miles. That would equate to about 100 engine hours of
operating time at 50 mph. Other people will have other experience.
Generally speaking, the cylinders need to be well filled with air fuel
mixture to generate sufficient pressures in the cylinders as well as normal
loads on the bearings. Many people recommend short periods of wide open
throttle (with a nervous eye on oil pressure and temperature) to aid in
break in. On engines that I am going to use, I drive 'em like I am going to
use them, but I balloon foot the accelerator for the first 5000 miles or
so, and gradually work the engine harder and harder. You will probably get
many opinions on this subject.
Salem, OR
78 GMC Royale 403
On Tue, Jan 31, 2012 at 4:28 PM, Greg and April
wrote:
> What do you consider a "good break in period"?
> Greg H.
> I don't just march to the beat of my own drum - I have an entire brass band
> to keep me company.
> ----- Original Message -----
> From: "Matt Colie"
> To:
> Sent: Tuesday, January 31, 2012 17:04
> If using it in an engine, you must establish a good break in before
> introducing the MoS2 or the engine may never completely seat critical
> components like piston rings.
http://temp.gmcnet.org/cgi-bin/mailman/listinfo/gmclist
