Original
xxxx
-------o-|* 4 1/4 inch inset
xxxx centerline of tread is 0.4 inches inboard of bearing set
(causing inner bearing to take 93% of load) 2,490#
New Alcoa (light truck) Wheel (brings front out to rear wheel track)
xxxx
--o-|* 1/4 inch inset
* * centerline of tread 4 inches outboard of bearing set
xxxx (causing inner bearing to support 11,190# down
vector and the outer bearning to support a 11,190# up
vector and remember that is just static loads)
That is where the 450% of original design loads
comes from.
x = tire tread
* = wheel structure
o = center line of bearing set
inset = distance from hub mounting face to center of rim
xxxx
xxxx
comes from.
x = tire tread
* = wheel structure
