HI jim,
No Carb....EFI. I guess I should have better defined grinding. When hot, the starter turns over very slowly. You can hear it just almost stopping
when it hits compression. Sometimes after a couple of compression stops, it goes normal and spins at normal speed and engine starts. Has never
happened since high torque starter. Just my experience.
> Try rebuilding your Carburetor. Might put a lower temp thermostat, too. You
> are having heat soak, but it won't effect a starter in good shape with
> adequate cables. It does boil the fuel and flood the engine.
> Salem, Oregon
> On Thu, Jan 2, 2020, 5:00 PM Larry via Gmclist
> > I've had troubles with "hot soak" starts. After a hot run in hot weather,
> > and stopping for fuel, the restart has always been a grinder. Tried
> > everything from parts house rebuilds to our local starter/motor rebuilder
> > with no success. Even went as far as building a sheet metal shield between
> > the exhaust manifold and the starter. It helped but didn't cure the issue.
> > I finally bit the bullet and got a "high Torque" starter off of eBay..
> > Starter with a high RPM, physically smaller starter with gear reduction.
> > Have had no hot start issues. JWID
> > Larry
> > 78 Royale w/500 Caddy
> > Menomonie, WI.
> > http://list.gmcnet.org/mailman/listinfo/gmclist_list.gmcnet.org
Larry
Menomonie, WI.
> Salem, Oregon
> > Larry
> > Menomonie, WI.
Larry
Menomonie, WI.
