Ignition Switch
Melbo
Member
Aug 19, 2018
155
10
18
75
I bought my '73 GMC without ever trying to start it. It was parked and trying to start it was not going to do me any favors. I knew it was going to
be a project. I had it towed to a storage facility. I checked to see if the onan was going to work and it was. I did the fuel system from back to
front. Time for the 455 to be checked out. I pulled the fuel pump and figured out that I need to change the timing chain and gears. I changed the oil
and filter. Put oil in all eight cylinders. Using a breaker bar rotated it to #1 TDC. Pulled the dizzy and pressurized the oil system. Time for a
compression check. Put a battery in then put the key in the key slot and the buzzer came on. Turned the key and it didn't feel right and nothing
happened. When I let go it didn't spring back like I am used to. I tried it a couple of times and it just did not seem right and nothing -- I mean
nothing from the starter. I tried it with jumpers and got the same. I checked the voltage at the primary wires at the starter and it was only 6
volts. I pulled the starter and it did nothing on the bench. So I pulled the alternator and took both the alternator and starter to my rebuilder. My
question is are the ignition switches common to replace and if that is necessary are there other issues I should check as I am going through this. I
just want to cover the stuff that will give me problems later on while I am into the middle of this.
TIA
Melbo
I think your jumping around too much.
First, see if the dash livens up.
Ifit does not, testing the starter is not the answer and dont wast your
time or money on an alternator.
Call me before you wast your time and funds (800) 752-7502 and ask for me.
On Mon, Dec 23, 2019 at 5:05 PM melmull--- via Gmclist <
> to
> oil
> this. I
> TIA
> Melbo
http://www.appliedgmcrvparts.com
Jim
Thank you for your response. I try to do things one at a time. My question now is does the 455 stay and is capable of good service OR does it come
out and go to my engine guy for a rebuild. AND if he tells me it isn't viable time for a crate engine. That is kind of the heart of the vehicle
portion of the GMC in my opinion. I understand that one pays the money and take the chance. The dash in the gmc is trashed. I am not sure why or
how and it really doesn't make a difference to me now because that will be a project all by itself. What exactly would I look for to "light up" on the
dash? The starter being non functional makes it impossible to do a compression test. Once the starter works I really don't need the key switch
operational to do the compression test. I was kind of curious if that is a common item that fails and how it fails. If it can be revived or it needs
to be replaced. I guess I can just leave it until it becomes a real issue and I can see that as I proceed I am going to have some major ones. Thanks
again for the response.
Melbo
First the answer to your ignitions switch, if needed. It is a common item and available from multiple vendors including Jim K. or Auto zone. It is
simple to change mounted on the lower steering column. Also the neutral safety switch is down there too.
Following Jim K's recommendation, Before you start throwing parts at it, you need to follow a systematic approach to your problem and prove the item
is bad before replacing it. Start with the cranking battery voltage readings under no load and when the key is turned to start. If it is good, then
clean battery cables and read the voltage to the starter and starter solenoid when the key is turned. ONLY if both are good should the starter be
removed. A reading of 6 volts says you have a bad battery or bad connection before the starter.
I would not consider working on the 455 before I got it running to see if there is really a problem.
Jim K. or any of us will help you if you are willing to shoot each issue one at a time.
You don't need the key switch to crank over the engine. Install a remote
switch to crank the engine.
Gene Fisher has a good write up on starting issues:
http://www.gmcmhphotos.com/photos/gmc-cranking-improve-for-free/p34368-bad-battery-connections.html
On Tue, Dec 24, 2019 at 1:05 AM Ken Burton via Gmclist <
> then
> be
> one at a time.
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
Bruce Hart
1976 Palm Beach
Milliken, Co
GMC=Got More Class
You can't evaluate the engine until it runs!
Your 6 V reading at the starter tells me you have a meter, but makes no sense and you don't tell us what you are metering across. First confirm the
meter. On 20 VDC scale You should have about 12.6 across the battery of a good vehicle. Then start the vehicle and you should have about 14 Volts or
more iif vehicle is cold. Now you know the meter works. Start by metering across you engine battery. You should see that 12.6. Below that charge the
battery and report back. Below about 12.4 the battery is very discharged and may not crank. Another no cost test is to turn on the headlights. If they
dim out when you try to crank, you have a bad battery or bad connection on the cables. If they stay bright then you have a bad starter, bad ign switch
or bad NSS or bad connections to them.
John Lebetski
Woodstock, IL
I agree with Bruce and I can operate the starer and do the compression test with or without the ignition switch working properly however I was asking
ahead. According to the flow chart on page 388 of the 73-74 maintenance manual I was supposed to "remove starter for repair" I did jump ahead with
the meter. The second flow chart shows a meter reading of 7 volts as the break off point. My starter is in for the rebuild. My more direct question
was when my meter reads 6 volts -- with the break off point being 7 volts it appears from the instructions that you are testing the starter switch
contacts. I could however be mistaken with that assumption.
I guess I should have been more detailed in my question and the process I am going through.
Thanks for the help with this.
Melbo
Starter troubleshooting can always be fun. And while the manual is very
helpful, unless you thoroughly understand why the manual is having you take
some specific action, the results can be very confusing. The nominal
voltage of the battery is 12 volts, and with small loads will remain 12
volts during operation of said small loads. The starter is not a small load
it is very large in fact. For large loads the battery voltage drops when
providing power for these loads. The troubleshooting charts are trying to
determine if the condition of the battery is poor enough that it cannot be
put back in service with the ability to maintain an acceptable supply
voltage under heavy load. I always keep a new fully charged battery
(condition known and monitored) in my shop just for
troubleshooting.purposes, I replace the battery of the circuit being tested
with this good battery, If things work, get a new battery, if not something
else is really broken and a fresh good battery will take all that voltage
guess work out of the equation.
Merry Christmas one and all!
On Tue, Dec 24, 2019 at 4:58 PM melmull--- via Gmclist <
> asking
> am going through.
> Melbo
Your switch problems point to a problem with either the (cast) gear or the action rod itself, based on "It doesn't feel right". However, I side with
the suggestions above. Take both battery cables off and shine them and the posts. If they are 'get by' cables (with the clamps secured to the cables
with a piece of metal and two bolts) remove them and save them with your other copper to recycle and buy proper cables/ Before you connect the new
ground cable, Remove EVERY heavy duty cable, shine it and its connection, and return it. Reroute them such that the positive cable goes directly to
the starter solenoid and another comes from the solenoid up to the battery paralleling switch, i.e. no connections in the cable from the battery post
to the starter solenoid post. This give the least drop to the starter.
--johnny
Braselton, Ga.
While I'm sure it happens, I've never had a starter on anything with bad or broken internal wiring. Not to say it doesn't happen, only that it never
happened to me. My problems with starters have been worn brushes, worn front bushings, failed solenoid connections, arced and cruddy slip rings and
rear bearings, pretty much in that order. Rear bearings are like throwout bearings... I've replaced a lot that were probably OK, but weighing the
cost of the part against the pain in the ass factor of replacing it says put another one in while it's apart.
--johnny
Braselton, Ga.
Low voltage. Hmmm, what could that possibly be? CHECK VOLTAGE AT THE
BATTERY POSTS FIRST. Then, the isolator top and bottom lugs. If they are
not the same, remove all your cables and make the connections BRIGHT AND
SHINY, like the Christmas star. THEN, check the voltage at the starter.
Salem, Oregon
On Wed, Dec 25, 2019, 8:32 AM Johnny Bridges via Gmclist <
> --johnny
> Braselton, Ga.
> in hell
Jim
Thank you for your response. When I see your posts I read them carefully. I am working on the learning curve here. Disconnecting and dropping a
starter is pretty simple and when it is bench tested with a fully charged battery and nothing happens my best judgement is take it to the rebuilder.
The shop that does my starters also does my alternators so I figured lets do a little preventative maintenance and took them both in. With them
enjoying the holiday season it could be a spell before I get them back. No problem I will do some following up of other portions of the start circuit
so when I get the starter back I will be sure that any voltage drop should be within tolerable ranges. I was just struck with the 7 volt reference in
the flow chart on the starter circuit. I only had 6.2 volts. The flow chart took me the same place BUT I was curious if the start switch could be
the culprit. By the time I get the starter back I will have a better understanding of the start circuit how to proceed.
Thanks again for the response
Melbo
Johnny
Upgrading the cables is definitely in the master plan. I have the first year model that was set up for three batteries -- one for the onan -- one for
the house system -- one for the start battery. I will be running a "00" pair of welding cables to the onan to eliminate that battery and will be
replacing all the large cables at the battery compartment (if you really can call it that) once I determine how many feet and number of connectors I
need from the electric supply house. Until I'm at that stage (which would have to include the house systems) I usually check for voltage drop (loaded
and unloaded) to see if I need to bypass something for better results.
Melbo
Melbo,
The 10MT starter is in actual fact, too robust. In service it will keep trying to work when it should have called quits long before. If you have a
good shop handy, support them.
You don't need 00 to crank the onan. But a better answermight be to make the systems with the house bank behind the apu to do both the house and apu
start. Then you can also put in the slide tray so that they are easily maintained.
Our 23 does not give us that option.
Matt at the daughter's and dabbing at phone screen
I am used to 24 volt house and start systems from the bus conversion I did. The voltage drop is hard on starters and that is the main function of the
cables to the onan. "00" welding cable is very flexible and I would put it in a conduit (flexible or rigid to be determined) and it is only rated for
175 amps. I am not sure the amp draw for starting the onan but I would guess it to be over 125 and "0" is only rated for 150 amps so I could be
approaching my max draw. One size up while you are doing it is easier than redoing it later IMHO. I like working with the "00" better than the
"0000". I still have a collection of sets of "0000" cable from different battery sets I have had and removed. I kind of like your idea of the
batteries in the back. The 455 starter could max out the "00" cables I would think. Don't those starters draw over 200 amps. Well all this is to be
determined at a later time. I like the multiple "P" expressions.
Proper Prior Planning Prevents Piss Poor Performance.
One step at a time and thanks for the help
Melbo
I would not worry about the cable to the Onan starter. All that genset needs is a decent motorcycle battery for its starting purpose.
Starter for the 455 or 403 is a whole different matter, though.
D C "Mac" Macdonald
Amateur Radio K2GKK​
Since 30 November '53​
USAF and FAA, Retired​
Member GMCMI & Classics​
Oklahoma City, OK​
"The Money Pit"​
TZE166V101966​
'76 ex-Palm Beach​
k2gkk + hotmail dot com
Sent: Wednesday, December 25, 2019 13:18
Cc: melmull
Subject: Re: [GMCnet] Ignition Switch
Melbo
If it was me, first up is a working chassis electrical system with proper cabling, cranking the coach and charging its battery. We used the same
Onans, rated 7KW in promotional vehicles the uprate due to better manifolding and better cooling where space wasn't a concern. Since they ran several
times a week, a separate battery and the genset stock worked just fine and kept us out of the vehicle 12V supply. In RV use, unless you're a lot more
diligent than I about keeping a maintenance charger on the battery, you're better off modifying the genset and using the house battery(s) in the
coach. Disconnect the Onan charging system.
---johnny
Braselton, Ga.
Johnny
That has been done. I have no electric power where I store and work on the coach so I got the onan up and running first. Then I refurbed the tanks
so I would have a good fuel supply. Now I am trying to determine if the 455 stays in or gets removed. One step at a time and I keep reading manuals
and this board and upgrade suggestions and ideas that show up. It is a project in the works and this board and the people who post here have already
saved me a lot of work and wasted time and I appreciate it.
I have a wish list but everything in sequence.
Just My Way
Thank you
Melbo
> Johnny
> tanks so I would have a good fuel supply. Now I am trying to determine if the 455 stays in or gets removed. One step at a time and I keep reading
> manuals and this board and upgrade suggestions and ideas that show up. It is a project in the works and this board and the people who post here
> have already saved me a lot of work and wasted time and I appreciate it.
> Just My Way
> Thank you
> Melbo
Melbo,
I like the way you think, and the fact that you are capable is refreshing. (Go read some other RV sites!!)
Now, I start my Onan with a little garden tractor battery. (A motorcycle battery was more expensive.) I think I measured the cranking current at
about 85amps. Then again, it is a BF and not an NH.
I really do suggest that you look at the arrangement of the house electrics in the later coaches. As said, the house battery in the front of the
early coaches seriously sucks. I don't have much choice as I don't have the space in the rear for a house bank.
I have to admit that the three battery arrangement has been good to me. Before we had the real battery monitor, we killed the house bank with some
carelessness (and electric refrigeration) and accidental left the marker lights on over night. This no real issue as the Onan saved the day.
As to removing the 455. The only reasonable replacement is the Cadillac 500. The Oldsmobile rear face of block and the need to pass the drive axle
under the crankshaft make this a very serious issue. The only other thing I would consider would be a Dave Lenzi installed 8.1L. That is something
for Dave to do because he is a confirmed wizard of GMC.
Matt - have a real keyboard now that I am home from Christmas dinner with the daughter and family.
Melmull,
You've asked at least a couple of times whether the starter switch could be
the cause of your low starter voltage. Despite all the good information
that's been provided, no one has explicitly answered that important
question. My answer is NO. The only function of the starter switch is to
provide current to the solenoid on the top of the starter. When activated,
that solenoid closes its internal, very large, contacts between the battery
cable and the starter's field and armature windings. When you measure the
voltage at the starter's battery terminal, you're measuring before those
contacts and excluding all sources of voltage drop except the intervening
cable, connections, and the battery itself. So, there's no obvious way for
the starter switch to cause low voltage at the starter.
HTH,
Americus, GA
Manny Brakes & 1-Ton, Troy-Bilt APU, etc., etc., etc.
www.gmcwipersetc.com
On Wed, Dec 25, 2019 at 1:29 PM melmull--- via Gmclist <
> Jim
> dropping a
> circuit
> Melbo
> Johnny
> for
> Melbo
What KenH said. However, it is possible for the contacts inside the solenoid to degrade. Put your meter on the 1 or 2 volt scale, negative on the
large bolt strapped to the solenoid and positive on the large bolt the battery cable connects to. Crank, and see what the drop is. Or quick and
dirty, take a (sacrifice-able) screwdriver and short the two large bolt terminals on the solenoid together. This bypasses the solenoid contacts.
The above being said, I'd still look for a bad connection in the heavy battery cables, INCLUDING the ground cable to the engine block. If they're all
tight and shiny and the screwdriver trick doesn't get a start, and theirs 12V at the solenoid, now you're justified in removing the starter. Which if
you do, simply renew the front bushing and rear bearing and brushes, and clean up the armature and undercut the mica between contacts on the armature
just a bit with a piece of fine tooth hacksaw blade. Score the side of the case into both the rear and nose pieces so it goes back together in the
same orientation it came apart. Stoddard solvent (mineral spirits) and a brush will clean it up before reassembly.
--johnny
Braselton, Ga.
