Very nice.
What's your plan for sound deadening and heat rejection there? That's going to want to get quite hot.
I haven't decided 100% on the flooring, carpet vs wood laminate. Either way I'll probably use Hush Mat, or something like the heat/sound insulation padding that is commonly used in Jeeps under the thin carpet.
This is exactly what I want to do in the cockpit of my coach. Where did you get your HushMat and how much do you need to cover the whole cockpit floor? Thanks Mike.
Those look great! Are they cushy, or do they actually feel like they're from a Japanese vehicle? I look forward to seeing them installed and reclined.Seats are here. Very good shape for used
I have a nice pair of front seats that were installed by PO. I believe they came from some newer Winnebago. They are power and have forward/backward slide, swivel and recline. Very comfortable for driving and its nice to have two extra seats way up in front when we are parked. I'll try to take a photo if you are interested to see them.Interesting. I've never seen seats that have all three things....swivel, recliner function, and slides. I've seen combinations of those three, but never all three in a single seat.
In the "stupid ways to mount a seat department.....check out the drivers seat from my coach when I bought it. That is a air ride trucker seat. It was seriously heavy. You can imagine my surprise when I found that it was attached to the floor with nothing but a few bolts through the plywood. ?
But do they have seatbelts?I have a nice pair of front seats that were installed by PO. I believe they came from some newer Winnebago. They are power and have forward/backward slide, swivel and recline. Very comfortable for driving and its nice to have two extra seats way up in front when we are parked. I'll try to take a photo if you are interested to see them.
Had to trim half a blade worth on each side, but now it they drop right in.
Circular saw with a guide clamped on to the piece. I've cut through aluminum sheet a bunch with that saw, but this 1/2" thick plate killed the blade.Did you use a table saw?Aluminum cuts like butter on a table saw with a carbide blade.
