Yesterday, the Vintage RVing came in the mail and I opened it last night. (Thank You Kim)
There is a good article about breaking in a rebuilt engine, the text has a lot that I think is good to read.
The diagram of coolant flow is about as wrong as it could be. It shows the coolant flow absolutely backwards. They could almost correct it by
turning all the little arrows the other way. They also miss the point that the coolant flow is around the cylinders and then back up the head and the
in between is controlled by the holes in the head gasket.
What I do not know is if that picture came with the article. Please read the note inside the front cover.
Whatever, I still value the publication and again, I thank all those involved for the effort to assemble it.
