Hi Keith. You are probably going to use a solenoid for ~ 150 psi rating. In looking for a brand to use maybe consider who has rebuild kits
available. Also maybe consider installing the 2 way valve between compressor and the bag backwards with the inlet side to the bag. This should hold
the bag pressure against the valve seat instead of treating it as back pressure trying to lift the seal off the spring and will leak past the seal
when the spring gets weaker over time.
> You want to use the solenoid with the highest flow coefficient or the the CV rating. The spec sheet should give you the CV rating of the unit
> that your considering to use. The size of the valve either 1/8", 1/4" or 3/8" is not a good indication of how much the valve will pass. A larger
> sized valve could actually have smaller internals than a 1/4" valve. Be careful on what you buy, check the spec sheets on CV ratings.
> J.R. Wright
> GMC GreatLakerTech Editor
> 78 Buskirk 30' Stretch
> 75 Avion Under Reconstruction
> Michigan
> > Definitely 1/4" no need for speed. In fact a 1/4" valve is faster than the rest of the system.
> > But if a 3/8 valve is cheaper I may use them.
> > Accuair is crazy expensive!
> > ________________________________
> > From: Gmclist on behalf of Jim DeMellia
> > Sent: Friday, March 2, 2018 1:05 PM
> > To: gmclist
> > Subject: Re: [GMCnet] What Air Soloenoids should I use?
> > Have you decided on what size valve? 1/4,3/8 or 1/2. SMC 3/8 tend to be
> > easier to get and the cheapest. 1/4" would be the best fit for the
> > smoothest fill/dump. 1/2" is overkill and the most expensive. I'm using
> > accuair 1/4" valve block now and is very smooth. Just some things to think
> > about some more. In case you didn't already have enough to ponder. Haha.
> > JimD
> >> Thanks Guys, from what I see Parker is the best, SMC is really good and
> >> the air ride guys sell them all over the place.
> >> So in interest of availability/performance and reliability I'm probably
> >> going to go with SMC.
> >> From: Gmclist on behalf of John Wright > powwerjon>
> >> Sent: Friday, March 2, 2018 11:50 AM
> >> To: gmclist
> >> Keith,
> >> I was in the Instrument Engineering Business for almost 40 years. Used a
> >> lot of Parker Hannifin solenoids along with the Asco brand over the years
> >> and there are a number of US made units that are good too. Since our
> >> coaches sit for sometimes long periods of time I would suggest using the
> >> better quality solenoid. The offshore solenoids are at best suspect for
> >> porosity or material quality. I would also suggest that you ask for and
> >> look at the manufacturers MTBF (Mean time between failure) testing for the
> >> solenoids and all US manufactures as well Europeans will be able to
> >> provide that. I would avoid the cheaper offshore units. Several years
> >> back I build a replacement Electro Level 1 solenoid pack out of Parker 316
> >> SS solenoids. Doing that would not be cost effective for keeping your
> >> price point down. Good is always better than cheap.
> >> J.R. Wright
> >> Michigan
> >>> So I need to be able to supply solenoid valves for the MicroLevel for
> >> people that have no system or the Power Level system.
> >>> theres a ton of choices, from nice Parker valves at $40 each to $8
> >> Chinese valves.
> >>> I'd like to offer a mid quality valve and if someone wants better, or
> >> cheaper, valves they can use their own.
> >>> So does anyone have any advice?
> >>> Thanks!
> >>> Keith
> >>> _______________________________________________
> >>> GMCnet mailing list
> >>> Unsubscribe or Change List Options:
> >> GMCnet mailing list
> >> GMCnet mailing list
C. Boyd
76 Crestmont
East Tennessee
