Water Tank Guages
clark searle
76
Had a similar experience on both counts for the fresh water tank. Sensor was
inoperative. Took it off, cleaned and greased the shaft with silicone grease
inside the rubber sleeve and put back on. Not confident it'll be a long term
solution, but works for now. As for the leak, I had two small cracks develop
running either way from the level sensor opening along the mold seam. Repaired
with Plumbers Goop and a layer of vinyl patch material. Important to let the
first coat of Goop get nearly dry before re-Gooping and adding the vinyl layer
(as flat and smooth as possible) plus a couple more coats of Goop. Let each coat
dry fairly well before adding the next coat or it will take a long time to cure
through. The Goop was the only adhesive that I found that seems to adhere to the
tank plastic reasonably firmly (I tried several others first).
Clark Searle
Mt. Pleasant, MI
> It seems that both water (fresh and grey) tank gauges are not registering.
> As far as the fresh water I filled the tank yesterday and the gauge needle
> still points straight down. In addition the water tank seems to have a very
> small leak around the housing of the gauge sending unit. I think this needs
> to be pulled and replaced but how do I determine this?
> The gray water tank needle also points straight down and I know there is some
> water in it. What do I do to determine if this is also not working?
> I new to this stuff so I would appreciate any leads on what to check.
> If they are not working properly where can I get new parts and how much do
> they run nominally?
> Thanks.
> Chris Taylor
> '76 PB
> Rochester, MN
Marine Tex by Travco Laboratories will adhere to virtually any material. It is sold
in marine supply & hardware stores. I repaired my fresh water tank & holding tank
years ago & the bond is still solid. Simple to apply.
> Clark Searle
> Mt. Pleasant, MI
> > they run nominally?
> > Thanks.
> > Chris Taylor
> > '76 PB
> > Rochester, MN
& GMC Schematics Web site &
& http://meltingpot.fortunecity.com/greenside/321/ &
