>Terry, I have been made to believe that Winterfeldt knows what he's about
>here. If anyone on this net has information or direct experience to the
>contrary, please speak now or forever hold your peace.
First, let me say that I have my doubts about ALL engine rebuilders when it
comes to the GMC motorohome. I have found Winterfeldt's information to
generally make sense, and base my following comments on an admittedly small
sample. However, not to be blocked by forever holding my peace, here goes
what I've seen and heard.
I have no direct information, but have seen a number of Winterfeldt engines
in for repair at a few shops. I bought a used Winterfeldt from the original
owner. He had several problems related to poor quality control. He had a
massive oil leak out the drain plug because Winterfeldt's forgot to tighten
the plug. He had another quality related problem that I don't recall the
details about. Winterfeldt make the repairs - no questions asked.
Another Winterfeldt engine that I saw has an excessive oil consumption
problem. Intake manifold was pulled and Winterfeld asked that they put a
new gasket set in. No good - there needs to be some machining done to bring
everything into tolerance. This is supposed to be a newly ( I'm about to install
>this thing and if I'm heading for trouble, I need to know that NOW.
>It seems to me that the problem with the old Fords was that the rad was too
>small for efficient dissipation to atmosphere with consequent heat build up.
>Moving up to the larger rad probably took care of 90% of the problem.
>Clipping paddles off the pump may not have been necessary except to abate
>the turbulence. And those older coolants and their recommended
>concentrations were not what we have today.
>Just some thoughts.
At some point restrictions in the intake or exhauist of the pump (and
system) will cause cavitation. Then you don't move much fluid and the pump
will erode. Also, turbulance can be a good thing or a bad thing depending
on the design.
Henry
Soquel, Ca 95073 / IP reviews
fax: (831) 462-5198
