Upper control arm bolt aprt #
LarryW
6,044
767
113
Menomonie, WI.
Anyone have a part # for the upper control arm bolts. The ones that have a flat spot machined on them to accept the cam for Camber/caster adjusting.
Thanks.
Larry
78 Royale w/500 Caddy
Menomonie, WI.
They are available with the cams, and nuts on the help tree display. No
access to part numbers here in Coos Bay, sorry.
> Thanks.
> Larry
> Menomonie, WI.
The part is listed in the GMCMI Parts Interchange under Front Axle, Control Arm, Shaft Kit. It is listed as Moog K5266 and NAPA 264-3620
NOTE TO KIM: To make it easier to find I suggest you add words after "Shaft Kit" to read "Shaft Kit Caster/Camber Cam Bolt"
Also add another part number:
AC/Delco 45K18020
> Thanks.
> Larry
> Menomonie, WI.
> AC/Delco 45K18020
> Emery Stora
> > adjusting.
> > Thanks.
> > Larry
Thanks Emery. Must be why I couldn't find it. Not clear in the product name.
Larry
Menomonie, WI.
Don't believe everything you hear, or read on facebook.
> wow, looks like there are a LOT of alternatives on these, if this list is
> correct:
> http://www.yoyopart.com/oem/11617522/napa-2643620.html
> I'm amazed since the Moog used to be the only known part. It appears it
> was used on many vehicles.
> However, I've also heard all the current replacements (Moog included) are
> Metric so don't fit as well.
> Karen
> 1975 26'
Thank you....will do so. Anyone else that updates, please do forward them
for inclusion.
Kimberlea Weeks
VP Administration and Convention Manager
612.501.4600 | f.866.519.0047 | www.gmcmi.com
GMC Motorhomes International
1402 So. Cage Blvd | Unit 273 | Pharr | TX 78577-6288
> AC/Delco 45K18020
> Emery Stora
> > Thanks.
> > Larry
> > Menomonie, WI.
> > correct:
> > Karen
> > 1975 26'
Believe it!! In This case the bolt is metric and slightly smaller in diameter and longer than the OEM it replaces. The cams themselves are also a
little larger in diameter which restricts the amount of camber/caster you can potentially dial in when turned to the extreems. Just what I observed on
my coach.
Larry
Menomonie, WI.
My posting had absolutely NOTHING to do with facebook. I found the part number references myself, and heard about the metric bolts from an
*extremely* reputable GMC source.
Karen
1975 26'
> > correct:
> > Karen
> > 1975 26'
Yes, Karen, I suspected as much. I gave a hasty answer. There are some
"bootleg" parts out there that are sometimes even packaged in containers
resembling Moog and other manufacturers. They are made of inferior
substandard materials and fit poorly. It has become a buyer beware market
when it comes to automotive parts. I have encountered the adjuster cams and
bolts myself, although they were not marketed as moog or Genuine G.M.
parts. Just plain white box with a number on the outside. It is not only
suspension parts, I have encountered ignition modules, starter solenoids,
alternator parts, just to name a few. Most of the time the bolts on
adjustment cams are damaged by idiots with impact wrenches instead of
torque wrenches. At least 1/4 of those bolts are ground away to index them
with the cams. They won't take a whole bunch of tightening before they
strip or twist off. Sorry I can't be more help.
> Karen
> 1975 26'
> > Jim Hupy
> list is
> > > correct:
> appears it
> are
> > > Karen
> > > 1975 26'
Here is the listing for O'reilly's
http://www.oreillyauto.com/site/c/search/Alignment+Cam+Bolt/02920/C0322.oap?model=Toronado&vi=1225752&year=1976&make=Oldsmobile
Just called my Napa store and there are 54 sets available in Tennesse.
Most likey to order the part shipping charges would be included.
> > Karen
> > 1975 26'
> > > Jim Hupy
> > list is
> > > > correct:
> > > > http://www.yoyopart.com/oem/11617522/napa-2643620.html#
> interchange
> > appears it
> included)
> > are
> > > > Karen
> > > > 1975 26'
Bruce Hart
1976 Palm Beach
Milliken, Co
GMC=Got More Class
I've run into some of those parts too. For example cam bolts that strip out even when using a torque wrench. I've learned to stick to the bottom end
of the torque range on these, and hope that it holds. No guarantee anymore of getting genuine parts, it seems no matter where you buy them. But as
they say, 'whaddya do?'
Karen
1975 26'
I salveded out a 73" a couple of years back and have at least one if not
two of these bolts available if anyone would want one.
> But as
> Karen
> 1975 26'
> and
> them
> > Jim Hupy
Bruce Hart
1976 Palm Beach
Milliken, Co
GMC=Got More Class
I believe at one time we used Ford parts.
> But as
> Karen
> 1975 26'
> and
> them
> > Jim Hupy
Applied/GMC, Fremont,CA
