Under cover temp.
darren paget
1,553
Don't know all the ins and outs but it seems to me that headers will
increase the under the cover temperature. Is this or is it not true.
Darren
> Guess we can disagree to disagree to disagree. One disagreement is that use
> of a thermostat lower than 195 degrees is a symptom of a dying car. Its a
> fact that higher thermostats were used as an emissions control supplement.
> One of my major concerns is keeping the under hood temperature down on the
> GMC, its just to hot for my taste. Open up that trap door after a good run
> and better be ready to get a real blast of super hot air in the face.
> Anything that I can do to reduce it is fair game. I am installing Thorley
> headers but have had them ceramic coated inside and out. I also plan on
> using a 180 degree thermostat. There is just to many positives not to use
> it. No one yet has given a valid reason to continue the 195 degree thermostats.
Darren Paget
76 Experimental
Another Fab Day
paget
http://www.TZEplus.com
Min.be are not on yet so I have no experience. However I can not imagine
raising it any higher than it already is with the regular cast iron ones. I
had mine ceramic coated which will supposedly reduce the temperature below
that of cast iron.
>Darren
thermostats.
> Darren Paget
> 76 Experimental
> Another Fab Day
> paget
> Darren
I don't know any of the technical reasons, but headers decreased both
the internal motor temperature and the heat under the cover. They also
improved the gas mileage.
Kara Kosier
77 EII
