A little over a week ago I was towed home from a trip (thanks to a Landol !!)
After all the In chassis diagnostics ( visual, fluid, Pressures, etc.) All showed acceptable or normal, The tranny needed to come out for further
diagnostics.
Today WE dropped the transmission and put it on the bench for further the needed investigation. ( A THOUSAND Canadian THANK YOUs to Don Blackwell for
the very Skillful and Effective Help!)
So far the main Problem has shown up and that is: the splines in the "Direct" Clutch Drum have been "Torn out" . Much like they were soft.
Metal Slivers are the only remains of those splines in the hub. The splines on the Gear Train input shaft (of the chain drive) looked fine
however. (The full Chain Drive Assembly is also in good shape)
I am curious as to what would have caused that stripping out.
I've been told that drum is Cast Iron and Performance Transmissions change it out to Steel. Which Makes it a known weakness. And Hopefully that's the
only thing wrong. All metal was contained in that area between the splines of the Input shaft, and nothing else has been circulating. ( fluid is
clean)
My mind has been tumultuously Running if I should Fix it and move on, or disassemble the rest of the gear train to investigate further. I suspect
the rest of the gear train is OK. Anyone have any experience with this as being common or actual problem.
Time to have some consultations in process! I'm not a transmission pro.
Hmmm?
Regards
John
John and Cathie Heslinga
1974 Canyonlands 260
455, Manny tranny and 1 ton, 3:70 LS,
Red Seal Journeyman, DTE, BEd. MEd.
Edmonton, Alberta
diagnostics.
clean)
Hmmm?
Regards
John
Edmonton, Alberta
