Towing Gearing
grant schaffer
94
1
Has anyone out there towed anything with a 3.42 or a 3.55 gear set in their coach? Has anyone done any calculations of the towed vehicle based on the
changes from the stock gearset to the 3.42 or 3.55?
thanks
1974 GMC Sequoia 26'
I only towed a box trailer 7000 miles or so with a 78 26 ft. ROYALE.
Crossed the rockies twice, the Grapevine, the Tehachapi grade, and the
Siskiyou's north on I-5 with 3:70 final drive and a 403. Wouldn't trade it
for anything else.
Salem, Oregon
On Fri, May 8, 2020, 5:25 PM Grant Schaffer via Gmclist <
> the
> thanks
Here is the calculation for different tire sized and gear ratios, Don Brown this a number of years ago.
http://www.gmceast.com/technical/Brown_Drive_Tire_Ratios.pdf
J.R. Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
78 GMC Buskirk 29.5’ Stretch
75 GMC Avion (Under Reconstruction)
Michigan
Home again after another adventure.
> for anything else.
> Jim Hupy
> Salem, Oregon
>> the
>> thanks
>> GMCnet mailing list
I looked at the table Jim and not exactly sure how your numbers for say the 3:42 ratio would change much per the 225 R75 16 tire size. These are my
specs but not sure how this answers the question on the transmission ratios posted. My engine is a 455. I’m also interested in towing and would
like to know my towing weight limits?
Thanks
TG
I have known of one instance that a GMC Motorhome 26 foot, with adequate
hitch hookups towed a trailer full of race bikes, tools, gear, beer, etc.
That had an all up weight of over 16,000 pounds. 455 engine, 3:70 limited
slip differential. Ran back and forth across the Cascades at Snowqualimy
Pass, and Santiam Pass with no problems. Easily would exceed 70 mph so
equipped.
Another with the same gearing tows race cars in a tandem axle trailer
with an all up weight of over 20,000 pounds with a 403. No issues there
either. I would consider those examples to be about the high limit of tow
weights.
Salem, Oregon
On Mon, May 11, 2020, 2:15 PM tom geiger via Gmclist <
> Thanks
> TG
Wow, that would for be more than a toad I was considering. Did not know she was capable of towing that much.
TG
Regulations vary by State, but there are more regulations regarding towing
than you can shake a stick at. Don't quote me on this, but they even go so
far as to tell you whether you need brakes on the toad if it weighs more
than 3000 pounds. I am no expert on this one.
Salem, Oregon
On Mon, May 11, 2020, 5:48 PM tom geiger via Gmclist <
> TG
Lower gearing will better the towing experience.
If you search opinions you will see if you have a 403, most (almost all) will say 3.7 gearing is best.
In 455
Engine coaches the opinions vary significantly. You want to tow heavy, go with lower gears such as 3.7.
My opinion on coaches I have driven, that is a little low for most purposes, but I probably would reccomend them if you plan to do lots of mountain
passes.
I have never been disappointed in any gear change for drivability off the line. I have 3.21 and
That little change made all the difference in starting off a stop light.
My friend has 3.42 we put in his and same thing. Mine cruises perfect empty, but his drives better hauling his tracker.
As far as towing is concerned,
I have hauled 4000-5000 pounds. Normally my towd is about 3300-3500. And I have hauled other lighter items.
It seems I would prefer to be light as practical with towing things 2000 pounds I really dont notice a big drag. But closer to 3000 you accelerate a
bit slower and have to give it
More gas to hold speed going up slight inclines.
It also depends on how you want to drive. Hauling 4000 pounds at 55-60mph compated
To 65-70
Is an entirely different thing.
Jon Roche
75 palm beach
St. Cloud, MN
I dont tow anything and it sounds like i need to replace my final drive gears.... gotta find me a set of used ones.
Rich Mondor,
Brockville, ON
77 Hughes 2600
I have towed with the stock 3.07 gears and with the current 3.70 limited slip. I generally cruise somewhere between 60 and 65 mph. I try not to be
in too much of a hurry anyway, and the gas mileage seems to be better the slower I go (within practical limits).
I use my second gear less with the 3.70 than with the original, and it comes off the line a bit quicker. I tow a 2003 Tracker at just under 3000#
just about everywhere and make an annual 52o mile trip to the dunes towing my '53 Willys Jeep on a trailer, sometimes with a Honda Odyssey ATV thrown
on for good measure. I estimate that load at 4000# - 4500
I also live and do most of my traveling in the West. My vacuum gauge is constantly varying from 2 in to 22 in of vacuum. Lots of ups and downs. An
8% grade is not unusual for several miles at a time. I really like the 3.70 for the above reasons.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
Rich M, re changing final drive ratio in your GMC Motorhome. I know you were a GM dealer mechanic so you
would know more about ring and pinions than the average guy.(not the knowledgeable people on here)
Because of the set up on the MH, there is/was a way of changing drive ratios(sort off) via the chain.
There were a couple of sources for the sprockets and chain, and it sounds less complicated than doing the
diff, unless you can get another diff/final drive assembly. Another way is to check the scrap yards for on of
the GM cars that came with the 3.21:1 . Front wheel drive something old.
Does any one have an extra chain or gears or complete final drive to offer to Rich ? I know Jim K offers this
assembly with brand new gears and different ratios but shipping from California to Ontario Canada could be a deal
breaker.
DAVE KING
lurker, wannabe
Toronto, Ontario, Canada
Dave,
There are several chain drive setups available depending on the sprocket size and chain length. The only one that I am aware of that is still available is from Manny which is a 3.50 ratio chain drive setup. There was a I think were a 3.42ish and a 3.70ish setups available from one of the Heritage Cruiser in Canada. I talked to him last spring and he was not making anymore assemblies at that time so that make Manny’s the only game in tow as a complete kit.
In our first coach a 77 Eleganza II with a 403 I put a 3.55 gear from Jim K and it was a great wakeup for the 403 and got it into the rpm range that worked. I could run with any 455 out there. The present coach that we now have is a 29.5’ Buskirk stretch with a 461 Jasper RV motor, with Accel Gen 6 MPFI and a 3.67 drive ratio which feature a 3.21 final drive and a 3.50 Manny chain drive assy. In all setups we use the 225 tire to take max use of the final drive ratio. The coach is fast and pulls the hills and mountains and we have used it going to Tucson from Michigan from 2011 to 2018. We don’t used for the trip any longer as it had to sit in the sun and it was hard on the paint, we drive by car.
J.R. Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
Michigan
Home again!
> breaker.
> DAVE KING
> lurker, wannabe
Although i've never do it personally it looks like just simply dropping the rear trany cover and swapping the chain/gears doesnt look possible with
the trans in the coach as it looks like the first cross member is in the way [pictures look like it at least]. I would be open to a chain/gear
swap....has anyone done just that and in the coach to boot?
> breaker.
Rich Mondor,
Brockville, ON
77 Hughes 2600
Just confirmed it with Manny....tranny has to come out for a chain/gear swap :cry: .... quess i'll have to wait and see if anyone on this side of the
river has a used final drive and/or final drive gear set for sale or live with what i have till i tear everything out for a rebuild some day.
> with the trans in the coach as it looks like the first cross member is in the way [pictures look like it at least]. I would be open to a chain/gear
> > breaker.
Rich Mondor,
Brockville, ON
77 Hughes 2600
It IS necessary to remove the transmission from the coach in order to swap
the chain. With that proviso, it's a very simple change, but one MUST be
very careful to properly seat the spring clips which retain the two chain
sprockets on their hubs -- if a clip breaks or is not properly installed
and comes loose, the sprocket will move aft until it contacts the chain
cover, creating an awful racket & metal filings. Jerry Work, Manny, and I
have a campfire tale about that! :-)
I installed the 3.50 Caspro chain drive (now Manny's) right after I bought
my GMC in '98. I was VERY happy with it. In never shared the qualms some
have about the additional torque loads it imposes on the transmission --
too many high-torque Cadillac engines (including my own) have been run
satisfactorily for me to worry about that.
On Tue, May 12, 2020 at 12:29 PM 6cuda6--- via Gmclist <
> > breaker.
> Rich Mondor,
> Brockville, ON
> 77 Hughes 2600
I am in a quandary with a 3.55 or a 3.70. I have always thought the 3.70 would be better especially towing. If a 5000 pound load weather a toad or
trailer will be fine with a 3.55 then maybe the Miles Per hour is a better trade off? Now if one wants to make a bet with heir buddies to put money on
a burn out in a 12,000 pound coach then certainly the 3.7 or 4.1 is the definate gear set. My hesitance is not being happy with the 3.55 or the 3.7.
Anything above 65 in with the 3.70 will be above 2800 rpms an thus engine noise. I would suggest with my new rebuild and now adding fuel injection,
the 3.55 may be the better deal. plus if you would like to go 70 MPH and keep the rpms down would also be good. Has anyone looked into the
transmission and if the 3.55 is more favorable that the 3.70 for shifting or heat?
I remember reading a article with GMCI 1995 I think, about the 3.42 that was originally designed by GM but of course took 20 years to finally come to
fruition was designed for our coaches, so I would think that the 3.55 would be better?
Thanks
Grant
Grant, GM did have the 3.42 on the drawing board with the 3.54.
Our 3.55 is the same, just an engineers rounding the numbers.
In 1990 Marvin Peck ( Gear Master) encouraged me to start doing a 3.70
ratio.
Only reason why we still carry the 3.55 is for people that think a 200rpm
makes a difference in noise.
Oh, we have a person in Michigan that assemble units for us.
We know from our customers that the lower gears DO NOT hurt the Gas Mileage.
I have been running a 4.10 for the last 70,000 miles with my 403. I still
drive it 75-80mph.
There are several running the 4.10 and like it when they are driving 55mph.
On Tue, May 12, 2020 at 9:15 PM Grant Schaffer via Gmclist <
> 3.7.
> or heat?
> would be better?
> Thanks
> Grant
http://www.gmcrvparts.com
I have a 1969 Dodge P.U. that was sold as a Camper Special. It came factory
equipped with a 383 cu.in. engine, a 3 speed heavy duty torqueflite
automatic transmission, and a 4:10 differential. Factory dual exhaust, etc.
The first original engine ran 211,000 miles until the pre-ignition and
detonation caused by the reformulated unleaded gasoline. I drove it 70 mph
whenever I was on the road with the 10 foot open road camper. Didn't notice
excessive engine noise with it, even with the 4:10 gears. Before the
gasoline was reformulated, I consistently got 10 mpg. Never better than 8
afterwards. Still got that truck, but it doesn't see much use these days.
Approaching 300,000 miles.
Salem, Oregon
On Tue, May 12, 2020, 9:50 PM Jim Kanomata via Gmclist <
> ratio.
> Mileage.
> drive it 75-80mph.
> better
> on
> > 3.7.
> > or heat?
> come to
> > would be better?
> > Thanks
> > Grant
> Jim Kanomata
> jimk
> 1-800-752-7502
Except for the trip most of the way home after buying the GMC, I've run the
3.50 chain or Jim K's 3.55 gear set. I run at the speed limit, whatever it
is (despite many follower claims of higher). I've been from Key West, FL
to Fairbanks, AK, always towing a Honda CRV, without finding any hill that
needed below 2nd gear. I've never felt underpowered (that was NOT the
reason for the "'cause I can" installation of the Cad500). If I had a 26'
rather than my 23', I'd go with Jim K's 3.70 gear set to compensate for the
additional weight.
On Wed, May 13, 2020 at 1:35 AM James Hupy via Gmclist <
> Jim Hupy
> Salem, Oregon
> > ratio.
> > Mileage.
> > drive it 75-80mph.
> 55mph.
> 3.70
> or
> > better
> money
> > on
> > > 3.7.
> engine
> injection,
> and
> shifting
> > > or heat?
> that
> > come to
> > > would be better?
> > > Thanks
> > > Grant
> > > GMCnet mailing list
> > Jim Kanomata
> > jimk
> > 1-800-752-7502
If you are going to be towing more then about 2500 lbs I’d go with the 3.70 differential . I used to tow a jet boat from your neck of the woods with
3.21 gears to the Colorado River (Blythe ) and it was good but towing a small car into the Sierra Nevada mountains a 3.70 gear set was a must have.
The fuel mileage didn’t seem to change much and engine noise at 65 wasn’t a problem when you consider the extra performance. It is a real bummer
if you are geared high and you are on a steep mountain grade towing your car in first gear and you don’t think you are going to make the top. This
is what convinced me to get the 3.70 gears .
Roy Keen
Minden,NV
76 X Glenbrook
