Tire Monitoring System
hawk ii
284
While researching another project - I ran across this very
interesting device from --> www.smartire.com
This system monitors pressure and temperature -- from INSIDE
each of the tires on a vehicle.
The xmitter in mounted around the inside circumference of the
wheel rim and consist of the following:
. Pressure and temperature Transducer
. centrifugal switch (activates the unit - saves battery)
. radio xmitter (433 mhz)
. lithium battery (avg life --7 years)
The dash mounted display unit:
. Programmable for alarms and alerts
. Displays REQUIRED PRESSURE / ACTUAL PRESSURE /PRESSURE
STATUS / TEMP for each tire
These units are available at Sears and Discount Tires for about
$500 for a 6 wheel RV system.
BUT - I understand that if enough of us in the GMC community are
interested that the price could be less the $250 -- if there are
sufficiant orders.
NO - I have no vested interest in this company -- I'm just
interested in there device --
If any of you are interested -- please let me know
Thanks
Pete Papas-Daytona Beach---Land of Hard Beaches & Soft Women
. ___________ (MY TOYS) ___________ (904)672-0571
. /_][__][] []| 1973 GMC M/H /_][__] [] | 1976 GMC M/H
. *O-------OO-* Painted Desert *O-------OO-* Royale R/Bath
.1976 Bi-Centennial Iron Head - Harley Davidson Motor Cycle
.1979 280ZX Datsun (First Production Year - 1 of only 1000)
.Home Page-> http://members.tripod.com/~mehawk_ii/index.html
Do You Yahoo!?
Seems like an awful lot of money for something that is so easy to check once
a day or so.
>sufficiant orders.
>Thanks
>Do You Yahoo!?
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
"The beautiful Mohawk Vally"
Cheap at twice the price if it saves running one tire flat.
It's the alarm feature that'll make it worth it... showing the tire pressure
is just a nice add-on.
Many tire events start out with a loss of air less rapid than a blowout and
and a 30 second, or even a 10 second advantage could save a lot of grief. It
certainly would've saved the scar my rig is showing :-)
Heinz
...still packing and tweaking :-)
once
> a day or so.
> >sufficiant orders.
> >Thanks
> >Do You Yahoo!?
> Tom & Marg Warner
> Vernon Center NY
> 1976 palmbeach
The cheapest and best insurance you can buy is good quality E rated all
steel 10 ply tires. I cannot see where a catastrophic failure could be
avoided with these devices. Fact is that when Cinnabar did their study on
tires, they found a very high incidence of low pressure in the tires caused
by 1) not checking them at all and 2) using a cheap tire gauge that was
inaccurate.
>Heinz
>once
>> a day or so.
>> >sufficiant orders.
>> >Thanks
>> >Do You Yahoo!?
>> Tom & Marg Warner
>> Vernon Center NY
>> 1976 palmbeach
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
[Admin note - Mike, Be sure you're using the right "From" address.
This one bounced. Patrick]
At $500 too much for my blod but at under $250 keep me posted. If price
gets good enough, I might consider 2 sets.
Mike F.
- -----Original Message-----
To: gmcmotorhome
Date: Saturday, June 19, 1999 6:49 AM
Subject: Re: GMC: Tire Monitoring System
>once a day or so.
>>sufficiant orders.
>>Thanks
>>Do You Yahoo!?
>Tom & Marg Warner
>Vernon Center NY
>1976 palmbeach
Heinz
I don't think we were ever told how much your Tire Sentry cost. Would you
mind sharing this info?
http://www.bytedesigns.com/gmc/tire.htm
Thanks
bdub
>Heinz
>once
>> a day or so.
>> >sufficiant orders.
>> >Thanks
>> >Do You Yahoo!?
>> Tom & Marg Warner
>> Vernon Center NY
>> 1976 palmbeach
Heinz
Thanks
bdub
>Heinz
>once
>> a day or so.
>> >sufficiant orders.
>> >Thanks
>> >Do You Yahoo!?
>> Tom & Marg Warner
>> Vernon Center NY
>> 1976 palmbeach
Hi Billy.
$595 was the magic number for Coach and Toad.
will adjust the website :-)
Heinz
> Heinz
> Thanks
> bdub
pressure
and
It
> >Heinz
> >once
> >> a day or so.
> >> >sufficiant orders.
> >> >Thanks
> >> >Do You Yahoo!?
> >> Tom & Marg Warner
> >> Vernon Center NY
> >> 1976 palmbeach
Pete
I'd be interested in one o these systems. Please keep us informed on your
progress.
Thanks
bdub
>sufficiant orders.
........snip.............
smartire -- Tire Monitoring System (TMS)
There website is http:/ww.smartire.com
Do You Yahoo!?
ASCH
Smartire - Tire Monitoring System (TMS)
let me try this one more time -- hope the url gets highlited
http://smartire.com
Do You Yahoo!?
I'm in for 250-ish, especially if it's within 6 weeks or so as that's when
I'll be changing my Alcoas ( I hope ). Even though I have the Tire Sentry
I'm thinking that knowing temp and actual pressure may have some additional
value, as in a stuck brake or overheating bearing may transfer some of that
heat to the rim and hence to the sensor.
Heinz
To:
Sent: Saturday, June 19, 1999 7:22 PM
> ASCH
> http://smartire.com
> Do You Yahoo!?
Pete... how about looking into it some?
Heinz
> Hey Heinz and Hawk.ii et al...
> > Even though I have the Tire Sentry. I'm thinking that knowing temp and
> > actual pressure may have some additional value, as in a stuck brake or
> > overheating bearing may transfer some of that heat to the rim and hence
> > to the sensor.
> At the possible $250 for a six wheel system, the sensors can't be too
> expensive. What if we asked them to include two additional sensors and
> mounted them on the front wheel someplace where the heat of an
> overheating front wheel bearing would reach faster than the rim of the
> wheel. I not a thermodynaticist, but I'm sure we've got one on the net.
> Maybe the rim on an alcoa is not too far away thermodynatically from the
> bearings and then again maybe not.
> "I do whatever my Rice Krispies tell me to..."
> John said, err "Frosty the Snowman" said, from inside a 1974 Glacier.
> to the sensor.
Patrick... when you get back,
Did your Dad have any clues before, during, after... his event happened?
Did the wheel feel hot, etc.?
Wonder if the big boys (Michelin etc.) as Tom suggested, would be
interested NOW... in our collective data if we were capturing it before,
during, and after, explosive decompression... as we could call it.
Remember how interested they were in getting the tires back (wasn't it
the failed one and the still good one). That could save a bunch of
dollars for them at the rates their own lab guys have to charge and all
the equipment they have to order. And with Heinz's already demonstrated
ability to allow several of us, maybe many of us, to send excell-ready
data to them... Heck they ought to be paying us to collect the data, and
provide the best and roundest and freshest Michelins culled for us right
at the plant. Then we would not need no stinking truing. I think we
could pay the UPS fees, it seems like the least we could do, if they were
going to supply the tires.
I hate to say it, but I think we could work a deal with someone that
would save us some money, save them a bunch of money, and get them some
data that they would probably never see otherwise.
You know MIT did something like this and got a bunch of companies to
contribute equipment, supplies, and or money, in return for sharing
access to the data. Some of the companies joined up just to see if the
data was any different than the data they already had, and/or to know
what their competitors were now learning from the data.
more later....
>Heinz
> > to the sensor.
See my other post for "noise" etc. Things were real hot when the
bearing failed, and I have no doubt that, if there were an effective way
to monitor hub temperature, it probably would have saved the hub and
knuckle. It probably didn't start making a lot of noise until all the
rollers were ejected and it would have been plenty hot by then.
Patrick
Justin,
Interesting comments, but I think he may be more than a little off-base
as, among other things, the inflation recommendations are "cold" numbers
with allowances made for heating.
Is the "two tires in 3,000 miles" experience with the GMC or an SOB?
And just so Tom doesn't have to ask, where they all steel radials or
steel belted with poly body plies?
BTW, I would never shoot the messenger - you run out of messengers
quickly that way.
Patrick
Patrick Flowers
Mailto:patrick
The GMC Motorhome Page
http://www.gmcmotorhome.com
Good job messenger but what was the rest of the story. Was the coach loaded
correctly and the tires the recommended ones for the coach. Were they E
rated or E rated all steel. Maybe 70PSI was underinflated for this coach.
>I have just returned from having my tires rotated and balanced. While waiting
>I visited with the manager about the trouble one of the fellows is having
>with his tires. I learned last night he has had two blow in 3,000 miles. He
>is carrying 70 psi in E range tires.(new tires) So now I'm just passing
>along the comments of the tire store manager, and they sell both Bridgestone
>and Michelin. I'm not 'pushing' this point of view, just passing it along.
>He said perhaps it is an over inflations problem. Then he gave me this
>advice. "Forget what the tire manufacture recommends, go with what the
>vehicle manufacture recommends because they know what it weighs and the type
>service the tire will be subjected to." Then he added...."remember tire
>manufactures must cover a wide range of usage when they stamp their
>recommendations on the tire"....and his last comment was "if you are
>inflating close to the limit, and you have a significant hot weather heat
>build up, you can exceed the tire's inflation capacity". Once again, his
>comments not mine. Don't shoot the messenger!
>Justin
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
