Is this what this is all down to paying over $3000 for a brake mod that
should cost less than $500. Sad.
Looks like the next thing to manufacture is a brake mod kit for under $500.
Right now I am getting remanufactured front calipers for $20. Use them on
all 6 wheels thats $120. Add adapter plates and guess we could get it down
to under $300. Any other ideas? Anyone got a Eldorado rear brake and adapter
for a model?
>Jim--
>I purchased the whole package from Leigh Harrison:
> Master cylinder kit (increased capacity)
> Front axle kit (larger calipers)
> Center axle kit with remanufactured hub $2096
> Rear axle kit $825
> Sensitized vacuum booster $200
> Parking brake kit $250
> Core charges (refundable) were added ($400 center axle hubs + $100 v.
>booster)
> Anderson Automotive (local GMC specialist) did the entire installation for a
>little over $600 labor. I installed new rear bearings at the same time. The
>installation was straight forward with all parts fitting nicely without any
>machine work required. The nuts holding the vacuum booster in place and the
>actuating rod nut caused some confusion ad to how to get at them --- seems the
>later model coaches had these buried in the dash and the only way to get at
them
>is to cut a part of the under dash out. It is not visible but kind of a
strange
>way to put things together (see Gene Fisher's pages--he has a good description
>which I found after we were finished). We thought we had a brake bleeding
problem
>--- soft pedal --- but Leigh assured us to drive it carefully, stop from 20 mph
>about 25 times and the pads would seat themselves and the pedal would firm
up. It
>did!!!
>There is a night to day difference in stopping. Pulling my Tracker Toad I
am able
>to stop just as quickly and effortlessly as stopping in my unladen Jeep
Cherokee.
>And there will be no more fade!!! I have not installed the parking brake (next
>week before leaving for Albuquerque) but I'm assured that it will hold even
with
>full power in low range. That is quite an improvement, to say the least.
Now I
>won't have to carry that heavy anchor and chain for my wife to throw out in
panic
>situations.
>As you can tell from the above, I'm sold on the brakes and Harrison's
package. In
>fact so sold that the 4-bag suspension from Harrison is next after Albuquerque.
>See you in Albuquerque???
>Gary
>North Bend, Oregon Coast
>> Gary,
>> I'm interested in better brakes and wondered about any improvements you found
>> with the Harrison brakes. How much do they cost and how hard/how much
time to
>> install? Thanks,
>> Jim
for a model?
>Jim--
> Rear axle kit $825
>booster)
them
strange
problem
up. It
>did!!!
am able
Cherokee.
with
Now I
panic
>situations.
package. In
>Gary
>> Gary,
time to
>> install? Thanks,
>> Jim
