Tom P confronted the pump Mfg to find out where they squire the bearing.
Some would not say, others using US made ones informed Tom .
Sent from my iPhone
>> So does anyone know if there are other pumps that meet the Roller/ball
>> bearing requirement besides the Cardone Select?
>> The Tuff Stuff pumps were mentioned... What about Flow Kooler? Any others?
>> I talked with Both Tuff Stuff and Flow Kooler. Tuff Stuff would not
>> divulge the Bearing Part number so its not verified...........Flow Kooler
>> is just not interested!
>> As far as I can discover, these are the only folks making new pumps with
>> new entrails, Eh?
>> Regards,
>> Tom Pryor
>> 4188 Limerick Dr
>> Lake Wales, Fl 33859
>> Cell 248 470 9186
>> Living on a waterfront is not a matter of life or death. Its more
>> important than that.
> Well I did a lot of searching and found the following cross reference. All of these numbers a
> "appear" to be the Heavy Duty variety that you want with numbers mostly ending in H or HD. There were 85 pages of vehicles that it fit and most said
> w/AC and heavy duty cooling. That said, I did look up the Auto Zone one and it was available by mail only. I do not want to research this any more.
> If I am going to get one by mail I would order it from Jim K at Applied GMC. The price would be about the same or cheaper, and you know that you will
> get the correct item the first time. There is nothing wrong with Cardone Products which is what I believe he is selling.
> Here is the List:
> Brands: ADVANCE, ADVANCE/CARQUEST WATER PUMPS, ADVANCE/DRIVEWORKS, AIRTEX AUTOMOTIVE DIVISION, ALL PRO/FMI, ASC INDUSTRIES, ASC INDUSTRIES (FRENCH),
> ASC INDUSTRIES (SPANISH), AUTOZONE/ DURALAST-ASC, AUTOZONE/BOSCH, AUTOZONE/CARDONE, BOSCH, CARDONE/CARDONE SELECT, CARQUEST, CARQUEST/CARQUEST WATER
> PUMPS, CARQUEST/DRIVEWORKS, CARQUEST/GMB, FMI WATER PUMPS, HYTEC AUTOMOTIVE, MASTER PRO SELECT WATER PUMP, MURRAY TEMPERATURE CONTROL, NOVAPACIFIC,
> PARTS MASTER/ASC, PARTS MASTER/FMI, PARTS PLUS NEW WATER PUMPS, UNI-SELECT CAN/PRO SERIES WATER PUMPS, US MOTOR WORKS
> Part Numbers: 20039H, 3-455HD, 347014, 51-2164, 55-21118H, 58-295H, 58-297H, 98033, AW1120H, CP1120H, CWP-455HD, NP021120H, PWP-455HD, T3086, US1120H,
> WP-455HD
> Good Luck
> Ken B.
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
