Tankless hot water heater
emerystora
14,608
1
1
I would think so. 17,000 BTU
is equivalent to 5000 watts.
The little electric heaters some use in their motor homes are usually 1500 watts and draw about 12 to 13 amp at 120 volts.
I use a 5000 watt electric heater in my workshop in the winter here in Colorado and I have to keep shutting it off because it gets too hot in the 20ft x 30ft shop.
> Emery Stora schrieb/wrote
>> That is about 17000 btu.
> Is that considered good enough for a 23' in an area that is temperature
> wise comparable to say Seattle?
> Best regards
> Peer Oliver Schmidt
> PGP Key ID: 0x83E1C2EA
> '76a Eleganza II 26', VA
> '73 Sequoia 23', Germany, SH
Emery,
The storage unit for the Kingsley in Houston has a 120 VAC / 50 amp service included in the monthly cost, I would like to have one
of the heaters you have for when I work on it when it's cold.
Where did you get the 5000 watt heater?
The Pedantic Mechanic
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Emery Stora
Sent: Tuesday, January 16, 2018 3:22 PM
Subject: Re: [GMCnet] Tankless hot water heater"
I would think so. 17,000 BTU is equivalent to 5000 watts.
I bought one 3 years ago and paid about $150. Here is one I found for only $70. It looks similar.
https://www.ruralking.com/heater-240v-garage-wlmnt-5000w.html
Do you mean to say that you have a 240 volt 50 amp?
I don’t think you can pull 50 amps from 120 volt.
> Emery,
> Regards,
> Rob M.
> Sydney, Australia
> To: gmclist
> Emery Stora
I have one very similar that I use to heat the finish room in my shop.
Works well. I think mines 6800watts but same concept. I run it on the 3000 watt setting unless the outside temp drops below 20.
Justin Brady
http://www.thegmcrv.com/
1976 Palm Beach 455
Emery,
The storage unit has a fifty amp RV plug that the Avion plugs into just like campgrounds.
I thought about this a bit and remembered that that plug supplies a 40 amp circuit breaker which is actually two 20 amp circuits:
http://www.gmcmhphotos.com/photos/aa-miscellaneous-photos/p33849-avion-120-vac-wiring-diagram.html
Sydney, Australia
Sent: Tuesday, January 16, 2018 10:39 PM
If you wire the two leads to the heater from the two side terminals of the 4 prong plug you will get 240 volts that is needed.
I would just put a 240 volt breaker into the electrical box (30 amp should be enough) and mount another outlet near where you’ll mount the heater. Or, you can mount a wire directly to the heater and not use a plug.
Frederick, CO
> Emery,
> Regards,
> Rob M.
> Sydney, Australia
> To: gmclist
> Emery Stora
Emery,
"Tanks" ;-)
When I click on the link: https://www.ruralking.com/heater-240v-garage-wlmnt-5000w.html
I get: Access To Website Blocked
I guess that their website sees I'm in Australia?
Would you please send me the companies name, address, email, and phone number.
Sydney, Australia
Sent: Wednesday, January 17, 2018 5:08 AM
Frederick, CO
> Emery,
> Regards,
> Rob M.
> Sydney, Australia
> To: gmclist
> Emery Stora
Hi all,
I followed Ray's example and put in the tankless water heater very similar to him. I just plugged off the two coolant lines in the bath area. However
I would like to remove them at some point to avoid the mishaps mentioned above. Does anyone have an idea where they originate from
Brian K
1977 Eleganza II, TZE167V100261
Bellevue, WA
Rebuilt 455, New brake system, a lot of Original Equipment ready to fall apart (discovering more as I go along....)
https://www.amazon.com/Comfort-Zone-Industrial-Electric-Ceiling/dp/B009F1SWH8
"Comfort Zone Ceiling Mount 208/240V Heater 3000 / 4000 / 5000 Watts CZ220"
Rick "who needs the shop one of these would mount in" Denney
On Tue, Jan 16, 2018 at 1:40 PM, Rob Mueller
wrote:
> Emery,
> "Tanks" ;-)
> number.
> Regards,
> Rob M.
> Sydney, Australia
> Stora
> To: gmclist
> Emery Stora
> 77 Kingsley
> Frederick, CO
> > On Jan 16, 2018, at 10:57 AM, Rob Mueller
> > Emery,
> like campgrounds.
> > Regards,
> > Rob M.
> > Sydney, Australia
> Emery Stora
> > To: gmclist
> > Emery Stora
'73 X-Glacier 230 "Jaws"
Northern Virginia
Rick
When I did a search for Rob I saw the Amazon one but it is essentially the same as the RuralKing one except for the price.
Amazon is $119.95 with free shipping while Rural King is $69.99 plus shipping. If you buy $99 from Rural King you get free shipping.
>> Emery,
>> "Tanks" ;-)
>> number.
>> Regards,
>> Rob M.
>> Sydney, Australia
>> Stora
>> To: gmclist
>> Emery Stora
>> 77 Kingsley
>> Frederick, CO
>>> Emery,
>> like campgrounds.
>>> Regards,
>>> Rob M.
>>> Sydney, Australia
>> Emery Stora
>>> To: gmclist
>>> Emery Stora
>>> GMCnet mailing list
> Northern Virginia
Emery,
Yes, but apparently Rural King blocks their web-site to non-US IP ranges,
and Rob couldn't follow the Rural King link and needed to know what the
device actually was. Now that he can see that, he can find out how to buy
it for delivery to Houston.
But I think I missed the point. I think he wanted to know how to reach
Rural King by telephone, given that web access wasn't working. Their number
is 1-800-561-1752.
Address:
RuralKing.com
4216 DeWitt Avenue
Mattoon, IL 61938
And I can't find an email address.
Rick "Rob has what he needs now" Denney
> Rick
> Emery Stora
> CZ220"
> >> Emery,
> >> "Tanks" ;-)
> >> number.
> >>dot com
Rick
I already sent all that information to Rob and also offered to purchase it for him.
> Emery,
> is 1-800-561-1752.
> Address:
> RuralKing.com
> 4216 DeWitt Avenue
> Mattoon, IL 61938
>> Rick
>> Emery Stora
>> CZ220"
>>>> Emery,
>>>> "Tanks" ;-)
>>>> number.
>>>> dot com
(800)561-1752
​$69.99
wrote:
> Emery,
> "Tanks" ;-)
> number.
> Regards,
> Rob M.
> Sydney, Australia
> Stora
> To: gmclist
> Emery Stora
> 77 Kingsley
> Frederick, CO
> > Emery,
> like campgrounds.
> > Regards,
> > Rob M.
> > Sydney, Australia
> Emery Stora
> > To: gmclist
> > Emery Stora
Emery / Rick,
Thanks Mates, I've got all the info I need to follow up as well as discussing it with John Sharpe re installing it.
Sydney, Australia
Sent: Wednesday, January 17, 2018 7:19 AM
Rick
> Emery,
> is 1-800-561-1752.
> Address:
> RuralKing.com
> 4216 DeWitt Avenue
> Mattoon, IL 61938
>> Rick
>> Emery Stora
>> CZ220"
>>>> Emery,
>>>> "Tanks" ;-)
>>>> number.
>>>> dot com
