Rick
When I did a search for Rob I saw the Amazon one but it is essentially the same as the RuralKing one except for the price.
Amazon is $119.95 with free shipping while Rural King is $69.99 plus shipping. If you buy $99 from Rural King you get free shipping.
Emery Stora
https://www.amazon.com/Comfort-Zone-Industrial-Electric-Ceiling/dp/B009F1SWH8
> "Comfort Zone Ceiling Mount 208/240V Heater 3000 / 4000 / 5000 Watts CZ220"
> Rick "who needs the shop one of these would mount in" Denney
> On Tue, Jan 16, 2018 at 1:40 PM, Rob Mueller
>> Emery,
>> "Tanks" ;-)
>> When I click on the link:
https://www.ruralking.com/
heater-240v-garage-wlmnt-5000w.html
>> I get: Access To Website Blocked
>> I guess that their website sees I'm in Australia?
>> Would you please send me the companies name, address, email, and phone
>> number.
>> Regards,
>> Rob M.
>> The Pedantic Mechanic
>> Sydney, Australia
>> AUS '75 Avion - The Blue Streak TZE365V100428
>> USA '75 Avion - Double Trouble TZE365V100426
>> USA '77 Kingsley - TZE 267V100808
>> -----Original Message-----
>> From: Gmclist [mailto:gmclist-bounces] On Behalf Of Emery
>> Stora
>> Sent: Wednesday, January 17, 2018 5:08 AM
>> To: gmclist
>> Subject: Re: [GMCnet] Tankless hot water heater"
>> If you wire the two leads to the heater from the two side terminals of the
>> 4 prong plug you will get 240 volts that is needed.
>> I would just put a 240 volt breaker into the electrical box (30 amp should
>> be enough) and mount another outlet near where you’ll mount the heater. Or,
>> you can mount a wire directly to the heater and not use a plug.
>> Emery Stora
>> 77 Kingsley
>> Frederick, CO
>>> On Jan 16, 2018, at 10:57 AM, Rob Mueller
>>> Emery,
>>> The storage unit has a fifty amp RV plug that the Avion plugs into just
>> like campgrounds.
>>> I thought about this a bit and remembered that that plug supplies a 40
>> amp circuit breaker which is actually two 20 amp circuits:
http://www.gmcmhphotos.com/photos/aa-miscellaneous-
>> photos/
p33849-avion-120-vac-wiring-diagram.html
>>> Regards,
>>> Rob M.
>>> Sydney, Australia
>> Emery Stora
>>> Sent: Tuesday, January 16, 2018 10:39 PM
>>> To: gmclist
>>> I bought one 3 years ago and paid about $150. Here is one I found for
>> only $70. It looks similar.
https://www.ruralking.com/heater-240v-garage-wlmnt-5000w.html
>>> Do you mean to say that you have a 240 volt 50 amp?
>>> I don’t think you can pull 50 amps from 120 volt.
>>> Emery Stora
>>> _______________________________________________
>>> GMCnet mailing list
>>> Unsubscribe or Change List Options:
>> GMCnet mailing list
>> GMCnet mailing list
> '73 X-Glacier 230 "Jaws"
> Northern Virginia
> Offlist email: rick at rickdenney dot com
