Tom,
To answer why not, sometimes I dry camp for several says without moving
coach, so engine heat is not good option. Same for electric only water
heater.
Also don't want to run engine or sometimes generator just to heat water,
especially when already have propane on board. Hence when came time to
replace water heater, seemed liked the best was to replace with tankless
heater.
Fay Curtis
Kneeland, .ca
76 Glenbrook
> I watched this subject being discussed over the Past several years and
> wondered why folks don't use the engine driven hot water feature in many of
> our OEM style hot water tanks. in other words use 180-210 hot water from
> engine coolant to heat water in the hot water tank fitted with a HEAT
> EXCHANGER. My Wife and our family sailed on the Great Lakes for about 18
> years and had no lack of Hot water. Sailors are conservative bunch so we
> became accustomed to dealing with "dry camping" life style. Would always
> run the Diesel engine for 30 minutes each day and always had hot water for
> dishes and showers. (Navy Showers)
> If your hot water tank is not fitted with the heat exchanger option you owe
> it to your self to check it out!
> See:
https://www.walmart.com/ip/Kuuma-120V-Front-Mount-Water-
> Heater-with-Heat-Exchange/33982683?wmlspartner=wlpa&
> selectedSellerId=2132&adid=22222222227022531264&wl0=&wl1=
> s&wl2=c&wl3=40970775992&wl4=pla-78913532192&wl5=9012200&
> wl6=&wl7=&wl8=&wl9=pla&wl10=113146354&wl11=online&wl12=
> 33982683&wl13=&veh=sem
> FROM APPLIED GMC SEE:
http://www.appliedgmc.com/prod.itml/icOid/518
> Regards,
> Tom Pryor
> 4188 Limerick Dr
> Lake Wales, Fl 33859
> Cell 248 470 9186
> Living on a waterfront is not a matter of life or death. Its more
> important than that.
