Tankless hot water heater
bd5av8r
526
Hi all!
What are the thoughts on tankless hot water heaters? Do the Jims sell them?
what models are recommended for a GMC? I like to have hot water through the
entire shower, and they are portable in size, so I thought why not.
Has anyone here used them and what are the thoughts on them?
Sammy
GMCless for now. :)
bdub attached the link to my tankless water heater installation. This is by far one of the best upgrades we've made to our coach.
Sammy,
also in my opinion it was one of the best upgrades I've done.
I went with the Girard brand about 4 years ago. Unlimited hot water is definitely the way to go! But I think everyone is making them nowadays.
I also changed out the shower hand held faucet to a house model and took out all the water restrictures. The hand held faucet also has multiple
settings so if I'm stopped at a overnight without hookups I can still shower in the morning on the low flow setting.
Enjoy! Scott
Scott Nutter
1978 Royale Center Kitchen, Patterson 455, switch pitch tranny, 3.21 final drive, Quad bags, tankless water heater, everything Lenzi.
Houston, Texas
Thanks, all!! :)
> Sammy,
> Enjoy! Scott
> Scott Nutter
> Houston, Texas
I followed Ray's example almost to the T, although I removed the existing Propane RV refrigerator that did not work, and basically remodeled that
cabinet so I could put in a couple shelves and a small "dorm room" refrigerator. I rarely if ever Boondock, so it made sense for me.
Here are some photos what I did.
So far it has worked great. Takes a little getting used to on flow, etc., but much better than having a tank.
Brian
http://www.gmcmhphotos.com/photos/member-galleries/p64059-water-heater-install.html
(Sorry, again, for the unrotated photos).
Brian K
1977 Eleganza II, TZE167V100261
Bellevue, WA
Rebuilt 455, New brake system, a lot of Original Equipment ready to fall apart (discovering more as I go along....)
On the other hand, SHE's not likely to use ALL the tank water if the hot
water goes way before then. :-)
> I
I watched this subject being discussed over the Past several years and
wondered why folks don't use the engine driven hot water feature in many of
our OEM style hot water tanks. in other words use 180-210 hot water from
engine coolant to heat water in the hot water tank fitted with a HEAT
EXCHANGER. My Wife and our family sailed on the Great Lakes for about 18
years and had no lack of Hot water. Sailors are conservative bunch so we
became accustomed to dealing with "dry camping" life style. Would always
run the Diesel engine for 30 minutes each day and always had hot water for
dishes and showers. (Navy Showers)
If your hot water tank is not fitted with the heat exchanger option you owe
it to your self to check it out!
See:
https://www.walmart.com/ip/Kuuma-120V-Front-Mount-Water-
Heater-with-Heat-Exchange/33982683?wmlspartner=wlpa&
selectedSellerId=2132&adid=22222222227022531264&wl0=&wl1=
s&wl2=c&wl3=40970775992&wl4=pla-78913532192&wl5=9012200&
wl6=&wl7=&wl8=&wl9=pla&wl10=113146354&wl11=online&wl12=
33982683&wl13=&veh=sem
FROM APPLIED GMC SEE: http://www.appliedgmc.com/prod.itml/icOid/518
Regards,
Tom Pryor
4188 Limerick Dr
Lake Wales, Fl 33859
Cell 248 470 9186
Living on a waterfront is not a matter of life or death. Its more
important than that.
Tom,
To answer why not, sometimes I dry camp for several says without moving
coach, so engine heat is not good option. Same for electric only water
heater.
Also don't want to run engine or sometimes generator just to heat water,
especially when already have propane on board. Hence when came time to
replace water heater, seemed liked the best was to replace with tankless
heater.
Fay Curtis
Kneeland, .ca
76 Glenbrook
> See:
> Regards,
> Tom Pryor
> 4188 Limerick Dr
> Cell 248 470 9186
That is good information, however my usage of a GMC will be off the grid
and the unit still for up to a week or so. The hot water heater will have
the duty to run without engine assistance.
Sammy
> the duty to run without engine assistance.b
Instead of LPG, I'll be using gasoline utilizing Eberspächer Hydronic
B5WS connected to the coolant circuitry in my 23' - heats the engine
with a coolant to air heat exchanger, and the water with the original
coolant to water exchanger.
Best regards
Peer Oliver Schmidt
PGP Key ID: 0x83E1C2EA
'76a Eleganza II 26', VA
'73 Sequoia 23', Germany, SH
While the engine coolant heated hot water is nice, remember that it is much hotter than typical house hot water. Also, if you have one, pay attention
to those long hoses. A break will cost you an engine. Don't learn the hard way like I did. If you are not using this function, install cut-off valves
in both lines and turn them off. Better yet, replace those 40 year old hoses.
Tom
KA4CSG
One way to think about this is that the tankless water heater is only using propane when the water is running.....and really, how often is that?? Not
very much.
Just another thing I've done, we do mostly boon-docking. So I built what I call a "water wagon". We go and fill it at the pump or water station,
wheel it back and connect it to the city water connection and I have a plug on the side of the coach for the 12vdc power for the pump. I host a
primitive campground every summer for 5 weeks and this makes my resupplying of water a piece of cake.
Water Wagon.....
http://www.gmcmhphotos.com/photos/g6747-water-wagon.html
Ray,
You are one CLEVER BUGGER as we say Downunder!
Regards,
Rob M.
The Pedantic Mechanic
Sydney, Australia
-----Original Message-----
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Ray Erspamer
Sent: Thursday, November 30, 2017 9:16 AM
Subject: Re: [GMCnet] Tankless hot water heater"
often is that?? Not
very much.
water station, wheel it back and connect it to the city water connection and I have a plug on the side of the coach for the 12vdc
power for the pump. I host a primitive campground every summer for 5 weeks and this makes my resupplying of water a piece of cake.
Water Wagon.....
Thanks for the cautious words. The coolant hoses are all new, and all I add to the original install is the gas powered heater up front and the water to air on the coolants way back to coolant to water heater near the bath.
Best regards
Peer Oliver Schmidt
'76a Eleganza II, VA
'73 Sequoia, Germany
> On the other hand, SHE's not likely to use ALL the tank water if the hot water goes way before then. :)
> Ken H.
That is a lot like my thinking about wanting a noisy water pump. But having had a young life with only the potable water we had in the tank did leave
an impression.
But, there is another problem that was demonstrated catastrophically by a friend with an hunting cabin, it could easily happen in a coach installation
as well.
Any on-demand single pass direct fired heater has to have good outside access to vent combustion by-products (exhaust). If you have a simple system
that heats for water demand only and the outside temperature falls below freezing. The water heater can be frozen a damaged. (Well, in this case
destroyed. His cabin now has an automatic dump that opens when the system is idle in cold weather.
The plan is good, but not all situations can manage a good installation.
Dan Greg's idea was a good one except for the freezing part.
Oliver, how many BTU's is that unit? You have room for it up front under the hatch? Shift the batteries to the drivers side I'd guess?
Hal
1977 Royale 101348,
1975 Eleganza II, 101230,
Rio Rancho, NM
On the standard GMC layouts, there's plenty of room behind the refrigerator for it and then there is the roof vent for the water heater venting.
