Suburban Install
shaun
65
So I've seen quite a few installs where the furnace is mounted on an angle (to match the wall angle), and I've also read the manual that says "DO NOT
MODIFY THE INTAKE OR EXHAUST PIPES." That being said, I am tempted to try one of three things:
1. Cut the stock pipe on an angle and weld it
2. Cut and install a flexible section (maybe not airtight?)
3. Purchase the optional extension kit and have it mandrel bent?
All three options would require a high temp flexible hose connection for the intake.
Any thoughts on this?
Shaun
Shaun:
Here’s a presentation on the ATWOOD install.
http://www.gmceast.com/technical/Swartzendruber_Atwood_Furnace_Install.pdf http://www.gmceast.com/technical/Swartzendruber_Atwood_Furnace_Install.pdf
It may give you some ideas.
Dolph
DE AD0LF
Wheeling, West Virginia
1977 26’ ex-PalmBeach
1-Ton, Sullybilt Bags, Reaction Arms, 3.70 LSD, Manny Transmission, EV-6010
> Shaun
Shaun,
I do not know if I am arriving in the middle of this thread but why do you
not just build an angled platform for the furnace?
Sully
77 eleganza 2
Seattle
> the intake.
> Shaun
From what I've seen, the angled mount requires more fabrication and modification to the existing area (i.e. cutting a notch beside the couch). Also,
by mounting flush with the floor, I could add a small shelf above the much shallower unit.
> Shaun:
> Here's a presentation on the ATWOOD install.
> Dolph
> DE AD0LF
> 1977 26' ex-PalmBeach
> "The Aluminum and Fiberglass Mistress"
> > "DO NOT
> > Shaun
This is my idea, but with a different furnace. The suburban only requires two small holes for pipes which I think could be cut on an angle or bent.
Shaun,
On the GMC Photo site there are several albums on furnace installs, just do a search on furnace or suburban.
J.R. Wright
GMC GreatLaker
Newsletter Editor/Publisher
Tech Editor
78 Buskirk 30' Stretch
75 Avion Under Reconstruction
Michigan
>> Shaun:
>> Dolph
>> DE AD0LF
>>> "DO NOT
>>> Shaun
>>> GMCnet mailing list
> Shaun,
> J.R. Wright
> GMC GreatLaker
> Tech Editor
> Michigan
> >> Shaun:
> >> Dolph
> >> DE AD0LF
> says
> >>> "DO NOT
> >>> Shaun
> >>> GMCnet mailing list
> >> GMCnet mailing list
> > bent.
Done this. Everything I can find shows an angled mounting bracket.
Shaun,
When I changed out the Solair with a Suburban NT 30, I ordered (from
Suburban)the external vent/exhaust tube for a Winnebago Elante. It is
manufactured with approximately the same angle as the side of our coaches.
Using that vent, the furnace can sit flat.
Terry
> > Shaun,
> > J.R. Wright
> > GMC GreatLaker
> > Tech Editor
> > Michigan
> > >> Shaun:
> > >> Dolph
> > >> DE AD0LF
> EV-6010
> > says
> > >>> "DO NOT
> > >>> Shaun
> > >>> GMCnet mailing list
> > >> GMCnet mailing list
> > > bent.
> > > GMCnet mailing list
Do you have any information on the part you used.
I searched the net and can't find any information for a Winnebago Elante suburban instalation.
I am in the process of installing a Suburban furnace on o flat plenum, and it looks like you solution can save me some time.
Part numbers would be great.
X2. I can't even find a picture of it...but I will probably end up cutting and welding mine, and then using some high-heat silicone hose for the
intake.
Mike,
I live in Washington state. I'M currently in Arizona, don't have my GMC
file with me.
When I did mine, I called Suburban told parts what I wanted. IRCC it cost
around $15.00.
Terry
> intake.
I found the part numbers.
Winnebago part number:
098668-01-707
Suburban part number:
260193
Although I still have not found a seller for this part.
An Internet search for 260193 brings up a Winnebago site
http://www.winnebagoind.com/service/wincd/1997/97w327rc.pdf http://www.winnebagoind.com/service/wincd/1997/97w327rc.pdf
That also shows the Winnebago part number.
An Amazon search for 098668-01-707 brings up
https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dautomotive&field-keywords=098668-01-707&rh=n%3A15684181%2Ck%3A098668-01-707 https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias=automotive&field-keywords=098668-01-707&rh=n:15684181,k:098668-01-707
Is that the part you need?
Frederick, CO
> 098668-01-707
> 260193
> Emery Stora
> 77 Kingsley
> Frederick, CO
> > 098668-01-707
> > 260193
Hard to say. It definitely doesn't look angled in the picture, but maybe they used the wrong photo?
The amazon is the wrong part number.
The winni site is where i found the part number.
I'm trying to see if winnebago has the part. Haven't heard back from them yet.
Looks like I may have the wrong part number.
The one I think I need is :
Winnebago p/n 092300-01-711
Suburban p/n x260179
The other one fits a lot of Winnebago with flat sides.
No picture on there parts list for the Elante.
I' m trying to get a picture of this part from Winnebago to confirm it is right.
Winnebago no longer sells parts for this furnace. They suggest going to suburban for the part.
So far no response from suburban.
