stupid generator
Seriously thinking about pulling my Oman 4K and converting to storage as we don’t use it either.
Randy Hecht
Roswell, GA
1974 Canyon Lands GMC Motor-coach
> I had it running nice last fall,
> Now it's running like an old soviet tractor, lots of smoke and no power.
> I've never actually used it for real in 12 years. Just worked on it and tested it.
> It's a big ol Onan Emerald, I'd probably gain an MPG by leaving it at home
> Keith Vasilakes
> Mounds View MN
> 76 exRoyale
> MicroLevelhttp://www.gmcmotorhomemarketplace.com/vasilakes/microlevel_intro.pdf
I would offer
To help. But I have a really bad track record when it comes to keeping generators working.
I can usually get them running, but they will fail you when needed. I am putting the hitch carrier and my backup generator(that has failed me too)
On for this weekend trip.
Can you check the voltage?? Onans like clean voltage to run well. Maybe slip
Rings??
Flight systems has some good troubleshooting.
https://www.flightsystems.com/troubleshooting/
Jon Roche
75 palm beach
St. Cloud, MN
> I had it running nice last fall, Now it's running like an old soviet tractor, lots of smoke and no power.
I'd be looking into a float problem in the carb. Lots of smoke = running rich.. and if you haven't moved the main jet adjustment then a float/needle
not closing correctly is about the only explanation. If I didn't find the problem in the carb then I'd look into ignition (dirty points, fouled plug,
etc).
Jim Miller
1977 Eleganza II
1977 Royale
Hamilton, OH
Kinda sounds like the choke is not opening after initial startup.
Salem, Oregon
> etc).
> Jim Miller
> 1977 Eleganza II
> 1977 Royale
> Hamilton, OH
Yeah probably carb, maybe choke, I'll check that before I remove it with some C4.
Probably not points since it's an Emerald not a original Onan
I just see all that storage space and weight and wonder why I'm hauling that boat anchor around
Sent: Monday, July 19, 2021 4:23 PM
Subject: [GMCnet] Re: stupid generator
Salem, Oregon
> etc).
> Jim Miller
> 1977 Eleganza II
> 1977 Royale
> Hamilton, OH
Probably could remove it, and fill that vacant space with spare parts that
you will never use and might outweigh the Onan.(GRIN)
Salem, Oregon
> some C4.
> From: James Hupy
> To: gmclist
> Jim Hupy
> Salem, Oregon
> float/needle
> plug,
> > etc).
> > Jim Miller
> > 1977 Eleganza II
> > 1977 Royale
> > Hamilton, OH
you know me too well!
Sent: Monday, July 19, 2021 4:54 PM
A working generator can really be helpful if
You lose your alternator but want to continue to drive
Your cab ac malfunctions, it’s hot out and you would like to continue to
drive.
Your dc/propane/ac fridge malfunctions and will only work on ac mid trip.
I’m sure there are other compelling reasons.
Sully
Bellevue wa
> From: James Hupy
> To: gmclist
Used mine a lot and for all the reasons you mentioned, plus making
cappuccino when we did not have hook-ups.
Salem, Oregon
> drive.
> Sully
> Bellevue wa
> > From: James Hupy
> > To: gmclist
> that
In my book, a good running gen is like a good spare tire.
Great to fire up the microwave,roof a/c.
> Generators are great when they work.
> Not so great when they don’t.
> Jon Roche
> 75 palm beach
> St. Cloud, MN
Jim Kanomata ASE
http://www.gmcrvparts.com
> Jim Kanomata ASE
Jim,
I hope you don't mind if I borrow that one from time to time.
> > Jim Kanomata ASE
> Jim,
> Matt
I've got a "good spare tire" around my waist...
And I'm usually the one that fires up the generator to run the rooftop ac and microwave...
Maybe that's what Jim was talking about ¯\_(ツ)_/¯
Mark S. '73 Painted Desert,
Manny 1 Ton Front End,
Howell Injection,
Fort Worth, TX
Besides the multiple problems that I have encountered with my original 6k Onan, the one that resisted rebuilding of the carb, jet adjustment etc. was
a terrible hunting rpm problem. Just for the heck of it, I sprayed carb cleaner on the carb while the unit was running and immediately the rpm
smoothed out. Found that the axle for the throttle leaves was so loose in the carb body that air was coming in through the gap throwing off the fuel
air mixture. Didn't have an immediate way of rebushing this but found a substitute carb on Ebay with almost the same manufactures number, installed
it and the Onan runs like new.
We supply rebuilt Onan carbs, not a one with a new kit only as that does
not address the worn parts.
On Tue, Jul 20, 2021 at 9:48 AM Robert J. Gogan
Jim Kanomata ASE
John,
10-4
On Tue, Jul 20, 2021 at 8:30 PM John R. Lebetski
wrote:
> A motorhome with no generator is a van
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
Jim Kanomata ASE
Right?? Haha
Sully
Bellevue wa
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
Update,
It looks like the float isn't shutting off the fuel so it's overfilling the bowl and running really rich.
If I pull the pump fuse it runs better until it empties the bowl.
Carb rebuild kit on the way.
Maybe I'll keep it 😋
Sent: Wednesday, July 21, 2021 11:07 AM
Right?? Haha
Sully
Bellevue wa
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
