> This looks great and your leather work is top notch. A small critique especially if you decide to leave the wood exposed. Stagger the top and
> bottom joints of the wood joints as much as possible. It will give the wheel more strength overall. It will probably not show with your wrap but it
> will cause a gap if left as finished wood. You would be surprised at how much a steering wheel flexes in normal use.
You're right, it could've used more offset, so time will tell. And I have to agree somewhat with the others, I was close to leaving it uncovered.
However, like I mentioned in the build, it wasn't quite perfect and the grain didn't match up. If I were to do it again, I would do a better job and
leave it uncovered.
leave it uncovered.
