Steering Wheel Rebuild
> This looks great and your leather work is top notch. A small critique especially if you decide to leave the wood exposed. Stagger the top and
> bottom joints of the wood joints as much as possible. It will give the wheel more strength overall. It will probably not show with your wrap but it
> will cause a gap if left as finished wood. You would be surprised at how much a steering wheel flexes in normal use.
You're right, it could've used more offset, so time will tell. And I have to agree somewhat with the others, I was close to leaving it uncovered.
However, like I mentioned in the build, it wasn't quite perfect and the grain didn't match up. If I were to do it again, I would do a better job and
leave it uncovered.
Very Well Done!
JD Lisenby- USAF Ret
1978 Royale-455
Electromotive Tec2 FI & ignition
Navarre, FL
Any way you could make an exposed wood wheel? I'd love to see that. Im sure
it would be awesome with your level of woodworking :)
Sammy
On Fri, Sep 30, 2016 at 4:12 PM, Jdlisenby <
> Very Well Done!
> 1978 Royale-455
> Navarre, FL
> Sammy
> > Very Well Done!
> > 1978 Royale-455
> > Navarre, FL
If someone has an extra wheel they are willing to part with I could give it a try?
