Thanks Emery.. I hadn't done anything with the rail, but the info you gave
about the
Wiring hit a home run... Rechecking, found one of the top lights shorted.
(with the bulb removed)
People should be aware that there is a distinct possibility of a shorted
socket.
Thanks again..
Jose'
Cc: Emery Stora
Subject: Re: [GMCnet] short
Have you done anything with your rail awning lately?
The rear top lights have usually been wired backwards by the factory. They
have the hot lead going to the shell of the lights and the ground wire going
to the bulb. Since the shell is screwed down to the fiberglass panel it
didn�t cause any problems but if someone has put on an awning rail that
touches the passenger side shell of the clearance light it is putting a
direct short from the hot lead to the ground. It is necessary to move the
clearance light a little to give clearance and if you have the inner panel
off the wires to the lights should be reversed to have the hot lead going to
the bulb.
If that is not your problem let us know and we may have other suggestions.
There is a ground connection for the lights near the license plate on the
inside. That often gets corroded and stops the lights from getting a proper
ground. Clean it up and put on some dielectric grease and use a star washer
to insure a good connection.
Frederick, CO
> Gentlemen..
> I have tried everything..a 20 amp fuse keeps blowing and I've run out of
> options. My clearance lights refuse to work ..Any ideas ?
> 73 sequoia
