Rust Neutralizer
patrick flowers
1,460
I came across an apparently neat product at Home Depot saturday. In
their paint department, they sell a product called "NeutraRust".
According to the label, it is non-toxic. It applies with a paint brush
like latex paint and cleans up with water.
I tried it first on my old water heater enclosure(I'm replacing the tank
with a Demaere stainless steel version) with good results. It dries in
about 15 minutes, but the instructions advise letting it cure for
several days before applying a top coat. It's available in blue, grey
and black. It's turns black when it cures over rust, so I bought the
blue in order to be able to see the color change better. According to
the label, it works as a primer after it sets up, so I'm planning to use
the rustoleum right over it. I'll let everyone know how it holds up.
It's a little pricey at $13/pint, but a little goes a long way.
Patrick
Patrick Flowers
Mailto:patri63
The GMC Motorhome Page
http://www.gmcmotorhome.com
Sam
You need to remove the rear panel on the bath module and can then access the
water heater unit from the backside
It is just a few screws to remove the entire rear panel
At least that is how I removed mine
Mike Linderman
- -----Original Message-----
To:
Date: Monday, July 13, 1998 2:21 PM
Subject: Re: GMC: Rust Neutralizer
>picksam I've got a problem. Hot water heater tank leaks.
>The book says pull it through the vanity doors once removed. I can't get
>there from here. Anyone with any suggestions. Thanks and regards; Sam
>Pickens Macon GA
Pickens Macon GA
> Sam
> access the water heater unit from the backside
I also had to remove the overhead cabinet and the woodwork around the
water tank. Also to make it a little easier, I cut the vent line that
runs up the back of the module and used a "no-hub" coupling to put it
back together.
Ain't no way it's coming out through the vanity!
Been there, done that!
Patrick
Patrick Flowers
Mailto:patri63
Thanks a heap. Keep the stick on the ice. Ain't none in Macon GA
> From: Michael Linderman
> To: gmcmotorhome
> Date: Monday, July 13, 1998 1:45 PM
> Sam
the
> Mike Linderman
> From: Samuel Pickens
> To:
leaks.
> >Pickens Macon GA
I appreciate the time for your reply. Thanks; keep the stick on the ice.
Sam Pickens Macon, GA
> From: Patrick Flowers
> To: gmcmotorhome
> Date: Monday, July 13, 1998 3:58 PM
> > Sam
> back together.
> Patrick
> Patrick Flowers
> Mailto:patri63
Depending on whether it is a type 1 or 2, drain the water heater,(be sure
that the engine is cold and no pressure at the radiator cap). remove
sliding doors, door frame and shelf liner, hoses and wires to the heater.
Heater should come out through the hole. Sounds easy probably tough.
>Pickens Macon GA
manual sure says it will come out that way. Why won't it come out. just
would like to know in case I have to do it.
>> Sam
>back together.
>Patrick
>Patrick Flowers
>Mailto:patri63
There is a fellow in Canada that sells a stainless steel water heater
that you can get. Its in the motor home news and he gives you
instructions.
Regards if you need more let me know
