Like these?
https://www.amazon.com/RUBBER-NUT-THREADED-INSERTS-THREAD-015-156/dp/B015EVZOU0/ref=sr_1_17?ie=UTF8&qid=1528326439&sr=8-17&keywords=neoprene+well+nuts
I got my LED lights from Grote. What do I use to hook up the wires? I keep hearing crimp connectors are bad- so I don't know what to use.
thanks
kelly
> The big advantage of the LED lights is the molded one piece construction.
> No leaks. The OEM lights are a guaranteed leak source, no matter how
> fastidious you are when you install them. The molly screws are the culprit.
> I always remove them, drill out the holes to fit neoprene "well nuts" and
> use all stainless steel screws, sealed down with 3M flexible sealant, not
> rigid adhesive. If there is any silicone sealant present, be sure and
> remove all of it. Just the residue from that crap will prevent a good deal,
> and it will leak again.
> Jim Hupy
> Salem, Or
> 78 GMC ROYALE 403
> > Chuck,
> > You're right! I didn't read the blurb carefully the ones I noted are
> > INCANDESCENT not LED!
> > At $11.99 and 10.99 that's a great deal!
> > Regards,
> > Rob M.
> > The Pedantic Mechanic
> > Sydney, Australia
> > AUS '75 Avion - The Blue Streak TZE365V100428
> > USA '75 Avion - Double Trouble TZE365V100426
> > USA '77 Kingsley - TZE 267V100808
> > -----Original Message-----
> > From: Gmclist [mailto:gmclist-bounces] On Behalf Of
> > Charles Boyd
> > Sent: Sunday, May 27, 2018 8:42 AM
> > To: gmclist
> > Subject: Re: [GMCnet] roof lights
> > Rob, I believe these are the LEDs.
https://www.summitracing.com/search/product-line/grote-industries-hi-count-school-bus-wedge-led-marker-lamps?tw=School%20bus%20&sw=G
> > rote%20Industries%20Hi%20Count%20School%20Bus%20Wedge%20LED%20Marker%20Lamps
> >> Kelly,
> >> Tom is 100% correct re being a PITA to change these IF the 6/32 screws
> > are rusted in and the rivnuts strip / spin in the roof.
> >> To R&R them spray them with penetrating fluid such as PB Blaster several
> > times over a week or so, then VERY carefully try to
> > unscrew
> >> them. Should the rivnuts spin you can get these to replace them:
https://www.mcmaster.com/#blind-rivet-nuts/=1d0urn0
> >> Be careful when you remove the wires, if the bullet connectors come
> > loose the wire will disappear under the roof and you'll have a
> >> hell of a time fishing it back out!
> >> As far as sealing them goes the Grote lights I sent you the link for
> > have THICK sponge rubber seals, I put a set on Double Trouble
> >> in 2008 and they haven't leaked yet. BTW you don't have to squash the
> > seal FLAT.
> >> Regards,
> >> Rob M.
> >> Sydney, Australia
> > Thomas Phipps
> >> Sent: Sunday, May 27, 2018 8:00 AM
> >> To: gmclist
> >> DOT requires the lights. If your State has vehicle inspections, it will
> > not pass without functioning clearance lights. Disclaimer:
> >> Alabama does not inspect privately owned vehicles.
> >> The LED replacements work well, but the color coded wires on the lights
> > are reversed. Install them once and seal them down with
> > your
> >> favorite gasket material that is not silicon.
> >> JmK and others have complete sets of proper LED clearance lights. If
> > your rivnuts are not destroyed by rust, the screw holes match
> >> up. Otherwise, it is PITA.
> >> Tom
> >> _______________________________________________
> >> GMCnet mailing list
> >> Unsubscribe or Change List Options:
> > C. Boyd
> > 76 Crestmont
> > East Tennessee
1978 Kingsley
Putney VT
