And dont forget the GPS screen
Rob Teed 74 Painted Desert
> -----Original Message-----
> From: owner-gmcmotorhome
> [mailto
wner-gmcmotorhome]On Behalf Of gene
> Sent: Sunday, December 05, 1999 12:55 AM
> To: gmcmotorhome
> Subject: Re: GMC: Right handed dashboard
> don't forget
> air/fuel ratio gauge left and right
> battery temp (engine and coach)
> ping detector
> house battery
> TBI indicator lamp and switch
> air pump on
> rear view TV
> Propane injector switches / lamps
> gene
> >Already have plans to put the Truecharge monitor up there somewhere.
> Generator
> >switch is a good idea. Plan to remove cluster in favor of tach. Don't
> want to
> >be eliminated on the basis of doubling up! Any idea where I can
> get a tach to
> >match the original Speedo/Odo?
> >> Ron:
> >> Can't answer your questions, you have doubled up some gauges
> and probably
> >> taken yourself out of the running for most gauges. Could add a vacuum
> gauge,
> >> then there is the old back up camera routine, probably should add a
> switch to
> >> start your gen set from the dash, maybe a gen set primer, maybe run the
> >> battery status gauges up there, me thinks money is the limiting factor
> here.
> >> Maybe the winner should be measured by how little dash
> material i.e. oak
> can
> >> be seen.
> >> Chuck D
> >> 78 Royale
> >> with the easy way out i.e. One of Mac's Panels.
> Genef -- 77PB/ore/ca
> GMC MOTORHOME INFORMATION
mr.erf
__________________________________________
NetZero - Defenders of the Free World
Get your FREE Internet Access and Email at
http://www.netzero.net/download/index.html
