WE supply on ours and Coop units the DOT fittings that are used on the Big
rigs, so if installed carefully they will hold the air long enough.
You also need to understand that there is no such thing as a Perfict work
on anything.
>> OK Gordon. I was not picking on you. I just did not understand why all
>> the concern over a 7 C temperature change.
>> You have an interesting problem there. It only leaks when cold below
>> freezing. I have no ideas on the cause for that. I agree that if it leaked
>> when the valves are shut off, that it is probably a bag leak but I also
>> have never worked on a 4 bag system so I do not understand the plumbing
>> involved.
>> On the soapy water idea, How about using some windshield solvent and soap
>> mixed together? I have never tried that. Maybe that mix will not bubble.
> My left front tire will hold air all year. Except during the very cold
> days of winter. Then it will go flat. Have never found leaks with water and
> bubbles.
> Gary W. Mills
> Livonia, MI
> . ___________
> ./_][__][] []| 1974 GMC M/H
> .*O-------OO-* Painted Desert
on anything.
>> involved.
> bubbles.
> Gary W. Mills
> Livonia, MI
> . ___________
