Required air pressure for quad bag rear suspension
WE supply on ours and Coop units the DOT fittings that are used on the Big
rigs, so if installed carefully they will hold the air long enough.
You also need to understand that there is no such thing as a Perfict work
on anything.
>> OK Gordon. I was not picking on you. I just did not understand why all
>> the concern over a 7 C temperature change.
>> You have an interesting problem there. It only leaks when cold below
>> freezing. I have no ideas on the cause for that. I agree that if it leaked
>> when the valves are shut off, that it is probably a bag leak but I also
>> have never worked on a 4 bag system so I do not understand the plumbing
>> involved.
>> On the soapy water idea, How about using some windshield solvent and soap
>> mixed together? I have never tried that. Maybe that mix will not bubble.
> My left front tire will hold air all year. Except during the very cold
> days of winter. Then it will go flat. Have never found leaks with water and
> bubbles.
> Gary W. Mills
> Livonia, MI
> . ___________
> ./_][__][] []| 1974 GMC M/H
> .*O-------OO-* Painted Desert
http://www.appliedgmc.com
> OK Gordon. I was not picking on you. I just did not understand why all the concern over a 7 C temperature change.
> You have an interesting problem there. It only leaks when cold below freezing. I have no ideas on the cause for that. I agree that if it leaked
> when the valves are shut off, that it is probably a bag leak but I also have never worked on a 4 bag system so I do not understand the plumbing
> involved.
> On the soapy water idea, How about using some windshield solvent and soap mixed together? I have never tried that. Maybe that mix will not
> bubble.
What about using RV antifreeze with dish soap mixed into it?
Vadim Jitkov
'76 Glenbrook 26'
Pullman, WA
Might be a bit of rust or dirt on the rim or even the tire! Low temps cause one or both to shrink a very small bit? Demount tire and hit both the rim and the tire bead with some fine grit sandpaper?
D C "Mac" Macdonald
Amateur Radio K2GKK
Since 30 November '53
USAF and FAA, Retired
Member GMCMI & Classics
Oklahoma City, OK
"The Money Pit"
TZE166V101966
'76 ex-Palm Beach
k2gkk + hotmail dot com
Sent: Saturday, February 17, 2018 10:38
Subject: Re: [GMCnet] Required air pressure for quad bag rear suspension
> involved.
> On the soapy water idea, How about using some windshield solvent and soap mixed together? I have never tried that. Maybe that mix will not bubble.
and bubbles.
Gary W. Mills
Livonia, MI
. ___________
> D C "Mac" Macdonald
> Amateur Radio K2GKK
> Oklahoma City, OK
> "The Money Pit"
> TZE166V101966
> '76 ex-Palm Beach
> From: Gmclist on behalf of Gary Mills
> To: gmclist
>> involved.
> and bubbles.
THX Mac  The last time I put a new tire on that rim.  I wire wheeled and
painted the rim. Next time I will replace the valve stem. Should work
unless there is a hair line crack in the rim somewhere.
Gary W. Mills
Livonia, MI
. ___________
Make sure the rim has a R stamped on it as the old rims were not rated for
Radial tire , also the 5year rule. Sounds redicules, but based on our
customers and my experiance, it is vey valid.
>> D C "Mac" Macdonald
>> Amateur Radio K2GKK
>> Oklahoma City, OK
>> "The Money Pit"
>> TZE166V101966
>> '76 ex-Palm Beach
>> From: Gmclist on behalf of Gary Mills <
>> daveel>
>> To: gmclist
>>> involved.
>>> bubble.
>> and bubbles.
> Gary W. Mills
> Livonia, MI
> . ___________
If you are still running 16.5" steel rims, you more than likely have a
welded spot seeping air. CURE? find the leak and grind it and weld it, or,
replace the wheel, or replace all 7 wheels with eagle or Alcoa hub centered
alloy wheels.
Salem, Or
78 GMC ROYALE 403
> >> D C "Mac" Macdonald
> >> Amateur Radio K2GKK
> >> Oklahoma City, OK
> >> "The Money Pit"
> >> TZE166V101966
> >> '76 ex-Palm Beach
> Mills <
> >> daveel>
> >> To: gmclist
> all
> leaked
> >>> involved.
> >>> bubble.
> >> and bubbles.
> > Gary W. Mills
> > Livonia, MI
> > . ___________
> Jim Kanomata
> jimk
> 1-800-752-7502
THX  Jim Hupy
I would like to get all 7 wheels replaced with eagle hub centered alloy
wheels.  I am waiting for Jim K to have the Hot Shot wheel design
reproduced.
> alloy wheels.
> Jim Hupy
> Salem, Or
> 78 GMC ROYALE 403
> and bubbles.
> Gary W. Mills
> Livonia, MI
> . ___________
The GMC right side used to fall down at 15 degrees F. This was when I winterized it and allowed it to get cold inside as well. It was 23 degrees
inside when it was 15 outside. Before I put a block under the right rear, I learned valuable lesson about door not opening enough for me to get in and
correct the situation :lol: Could not find leak after pumping system back up while running engine and compressor. Surmised it was the supply line to
the right bag, and the control valve also leaking system air to the bag when there was enough pressure differential. Bags and system held up all the
rest of the year. Found problems next temp drop(using leak check that doesn't freeze)...PLASTICS...did not warm up engine or interior, used external
compressor for air in system. In addition to the internal valve leak, the plastic hose compression type connection for the right bag leaked when it
got that cold. Fixed the hose with warmth followed with a little bit of disassembly and rework. Still haven't found the rebuild kit for the valves,
but was informed of JR's replacements. I'm too cheap right now for new valves, and have further system mods being added on which may get incorporated
into that system. There are some compression unions under the coach that didn't leak back then, but after they got blasted with exhaust leakage last
summer (muffler explosion) they leaked to the point that the system only stayed up for about 15 minutes. Was able to stop leakage by tightening, but
reworked 2 of the connections to be sure. Those connections are not supposed to be there, I can tell by the way the hoses ended up being routed. Muff
explosion due to ignition cutoff from electrical spike must have happened to the P.O. also :? The temperature changes really affect the plastics...all
of them...
Terry Kelpien
ASE Master Technician
73 Glacier 260
Smithfield, Va.
"I am waiting for Jim K to have the Hot Shot wheel design reproduced."
Is this a rumor or a possibility? I really like that wheel design from Alcoa and admire Eric Tanner's set on his. I would be a customer for those 8)
Terry Kelpien
73 Glacier 260
Smithfield, Va.
Terry,
Jim K sells rebuild kits for the OEM Powerlevel valves:
http://www.appliedgmc.com/prod.itml/icOid/953
Regards,
Rob M.
The Pedantic Mechanic
Sydney, Australia
-----Original Message-----
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Terry
Sent: Wednesday, February 21, 2018 12:31 PM
was 23 degrees
the supply line to
held up all the
leaked when it
for the valves,
get incorporated
tightening, but
being routed. Muff
the plastics...all
of them...
Terry Kelpien
73 Glacier 260
Smithfield, Va.
Too expensive and not enough interest,
Sent from my iPhone
> Terry Kelpien
> 73 Glacier 260
> Smithfield, Va.
OK, thanks Jim. Thanks for the info Rob, I didn't know Jim had those kits for the valves.
Terry Kelpien
73 Glacier 260
Smithfield, Va.
I can say we have most everything for the GMC MH.
Go to our web site and tripple click on the pictres and see better.
Our guys spend lot of time working on them for you.
WWW.appliedgmc.com
> for the valves.
> Terry Kelpien
> 73 Glacier 260
> Smithfield, Va.
http://appliedgmc.com/prod.itml/icOid/953
On Wed, Feb 21, 2018 at 12:14 AM, Jim Kanomata
> WWW.appliedgmc.com
> > for the valves.
> Sent from my iPhone
>> Terry Kelpien
>> 73 Glacier 260
>> Smithfield, Va.
Jim
How many sets of "Hot Shot" wheels would you have to sell to make it
cost effective?
Gary W. Mills
Livonia, MI
. ___________
