On the parking brake caliper they require a pad that has a short stem that
prevents the piston from rotating when the parking brake is applied.
Also the only way one can keep them adjusted is to use the parking lever
frequently as that action adjusts them.
On Sat, Jun 26, 2021 at 7:31 PM Emery Stora via Gmclist <
> So, Trevor
> When did your po install those calipers?
> I installed the TSM system many years ago with Cadillac calipers but I
> removed them within a year because I couldn’t keep them in adjustment.
> I took off the TSM system when I installed Lenzi’s system on my mid axle.
> I can measure the TSM disks if you would like. I also have records that
> show what GM vehicle they came from.
> Emery Stora
> 77 Kingsley
> Frederick CO
> > On Jun 26, 2021, at 8:20 PM, Russell Mehlenbacher
> > Thanks for confirming that for me. I probably won't get to it this
> year,but one day.
> > Russ
> > Russ & Linda Mehlenbacher
> > Rochester Hills, Michigan
> > '76 Eleganza
> > '74 Sequoia
Jim Kanomata ASE
http://www.gmcrvparts.com
