Rear bearing seals
Feb 6, 1999
135
Was just going thru old posts trying to find post on steering box to
send to Arch when I came across post from Tom Warner on 2/14. Anyway
Tom posted #s for rear bearing inner and outer seals. I just replaced
rear brngs and book showed no seal for outer bearing. Does anyone know
if there should be outer seal and why its not in GM parts book?
Bill &^ Edgemont
Emery this is the post I was referring to
Bill
Subject:
Re: GMC: Rear bearing seals
Date:
Sun, 14 Feb 1999 09:23:25 -0500 (EST)
"Thomas G. Warner"
Reply-To:
gmcmotorhome
To:
gmcmotorhome
inner seal is Federal 5123, national 5123, NAPA 47471, or Delco 290-19.
OUter seal is Federal 5109, National 5109, NAPA 47470, or Delco 290-17.
>Is any one make of seal better? Grease Mobil 1? Does some one have the
>numbers.
>Frank SW Indiana
>Home of Toyota
> TUNDRA
>______________________________________________________
>Get Your Private, Free Email at http://www.hotmail.com
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
> Here's a message I posted on 4/22/99:
> I decided to replace some of my rear bearings and cones and I needed new
> seals for the installation of my disc brake kit. I went to AutoZone and they
> only had one seal and no bearings. Same with Pep Boys and Car Quest.
> Finally went to Checker (known as Kragen on the left coast). Checker had all
> the parts in stock and were cheaper than AutoZone. They carried Chicago
> Rawhide (CR) which is an old line US manufacturer. When you look closely at
> the inside bearings you see "Mexico" on them!! The outside bearings are made
> in Germany. The outside cones and seals made in USA.
> The seals are Part No. 21771 and costs $3.89 each.
> The inner cone (cup) is LM501310 , $3.89.
> The inner bearing is LM501349 , $8.29.
> The outer cone is BR15243, don't remember the cost.
> The outer bearing is 15103-S, don't remember the cost.
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
