"starter bracket had been broken previously and this is probably the
reason.
I haven't figured out how to cure the problem yet, but it will probably
require cubic dollars (new slides? mounts?) knowing the cost of Onan
stuff."
I don't know how your motor mounts look but mine were still intact and
solid.
I dismantled the mounts and inserted sufficient flat washers
(the size will be easy to determine after dismantling,
somewhere about 1/2" diameter) to raise the Onan up off
the floor of the compartment.
Cost must have been all of $1.50. I hope your motor mounts are still
in good enough shape to permit this fix to work.
Good luck
Regards
Gary Zingle
1973 GMC 26 foot
reason.
stuff."
solid.
Good luck
Regards
Gary Zingle
1973 GMC 26 foot
