Raise Onan from floor of enclosure
gary j zingle
326
"starter bracket had been broken previously and this is probably the
reason.
I haven't figured out how to cure the problem yet, but it will probably
require cubic dollars (new slides? mounts?) knowing the cost of Onan
stuff."
I don't know how your motor mounts look but mine were still intact and
solid.
I dismantled the mounts and inserted sufficient flat washers
(the size will be easy to determine after dismantling,
somewhere about 1/2" diameter) to raise the Onan up off
the floor of the compartment.
Cost must have been all of $1.50. I hope your motor mounts are still
in good enough shape to permit this fix to work.
Good luck
Regards
Gary Zingle
1973 GMC 26 foot
>solid.
Sometimes they look OK even when they are squashed a bit. I had the same
problem last year. I replaced the two front (drivers side) motor mounts and
it raised the engine a good 1/2" or more. The new mounts are tall and firm.
They get compressed a bit when installed but are firm enough to keep the
motor off the floor of the compartment. The old ones looked OK but where
too soft.
Dave
Ann Arbor, MI.
73 Sequoia (26'/455/EFI/HEI)
