Ragusa Welcome Step
Yes, I hit a rock going down a winding driveway a few years ago. I took it to a shop that can weld aluminum and they weeded back the end that has a pin and it looks good and has held up fine for over ten years.
Frederick, CO
> Has anybody had success with welding a broken Ragusa welcome step. Grandson-in-law left it open and hit a curb.
> PeterG
> 23ft 73
> Calgary Alberta
Same here, Welded mine about 10 years ago after hitting something in a road construction area. No problems.
To expand on Jim’s comments, gas tungsten arc welding, also known as tungsten inert gas welding (TIG) , is an arc welding process that uses a non-consumable tungsten electrode to produce the weld. A filler rod of aluminum which matches the material being repaired is then melted into the puddle. This gives a very clean and strong weld as the inert gas prevents the weld from oxidizing.
Frederick, CO
> Since it is Aluminum, have it Tiged. A bull Sh-- name for using a more
> sofisicated way of welding.
>> had mine welded no problem
> Jim Kanomata
> Applied/GMC, Newark,CA
I’d be happy to take the broken one off your hands if you decide to get a new one... :-)
-Dave
1978 Transmode near Pittsburgh.
> PeterG
> 23ft 73
> Calgary Alberta
