To expand on Jim’s comments, gas tungsten arc welding, also known as tungsten inert gas welding (TIG) , is an arc welding process that uses a non-consumable tungsten electrode to produce the weld. A filler rod of aluminum which matches the material being repaired is then melted into the puddle. This gives a very clean and strong weld as the inert gas prevents the weld from oxidizing.
Frederick, CO
> Since it is Aluminum, have it Tiged. A bull Sh-- name for using a more
> sofisicated way of welding.
>> had mine welded no problem
> Jim Kanomata
> Applied/GMC, Newark,CA
