Putting transmission into park doesn't hold the coach
peer oliver schmidt
1,261
Mark and I noticed this. Any easy fix for this? This was in his parking
lot (not steep at all).
Best regards
Peer Oliver Schmidt
PGP Key ID: 0x83E1C2EA
'76a Eleganza II, VA
Sheared parking pawl. About the last thing that comes out of the case.
Inexpensive part, but costly to repair. There is a remote possibility that
the shift cable is not adjusted correctly, but, that is usually just
wishful thinking. Your experience may vary. For the final EXPERT answer,
consult with Manny T.
78 GMC ROYALE 403
On Apr 11, 2017 12:30 PM, "Peer Oliver Schmidt GMC"
Best regards
Peer Oliver Schmidt
Probably just the shift lever out of adjustment. Scotch the coach, put lever in park. On the transmission shifter rod going to transmission lever
loosen the adjuster bolt then push the transmission lever all the way in park. Tighten bolt.
> Best regards
> Peer Oliver Schmidt
C. Boyd
76 Crestmont
East Tennessee
> Mark and I noticed this. Any easy fix for this? This was in his parking lot (not steep at all).
> Best regards
> Peer Oliver Schmidt
I wasn't too concerned. I thought it was your technique. You weren't treating it like a 40 year old Detroit automatic. You gotta slam that sucker into
park.
Next time I drive it around the block I'll verify that. For now, I'm just leaving it chocked.
73 23' Sequoia 4 Sale
Upper Alabama
Mark,
I try that every now and then on my kids... Somehow, it doesn't help
with them :D
Let's hope it was my stupidity and not anything major!
Best regards
Peer Oliver Schmidt
> I have this same problem, could it be the parking pawl not engaging the drum correctly?
Could be the shift cable needs adjusting. Or it might be a real expensive job.
On mine, I'll see if I can get it to hold by shifting into park the way I always have (pull the lever back and quickly and firmly push it into park).
If that fails, I will try adjusting the cable.
If that fails, I am leaning towards driving it into the lake.
Upper Alabama
I'll bet if Y'All will follow Chuck's instructions, your parking pawl
problems will disappear. The lever should move easily into the P position
and the coach STAY PUT.
> drum correctly?
> job.
> Upper Alabama
Chuck is right. Definitely an adjustment problem. There is NO WAY you should have to "slam that sucker into park". Follow Chuck's simple adjustment
procedure and you won't have any more problems putting it into park.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
Solar battery charging
That parking pawl inside the transmission has a severe case of the
"fragiles". If the coach is moving, even a little bit, and someone "slams
that sucker into park" you can full well expect to be "taking that sucker
apart, and replacing the parking pawl" Pays me now, or pays me later, your
choice. The TM 425 is a rugged, reliable transmission, but, it doesn't care
much for being "slammed" into gear.
78 GMC ROYALE 403
> adjustment
> Carl Stouffer
> '75 ex Palm Beach
> Tucson, AZ.
> Eagles,
> That parking pawl inside the transmission has a severe case of the "fragiles". If the coach is moving, even a little bit, and someone "slams that
> sucker into park" you can full well expect to be "taking that sucker apart, and replacing the parking pawl" Pays me now, or pays me later, your
> choice. The TM 425 is a rugged, reliable transmission, but, it doesn't care much for being "slammed" into gear.
> Salem, Or
> 78 GMC ROYALE 403
You folks are overreacting. Nobody said anything about rolling or even rocking. But it has to know you mean business, especially if it is a little
worn and getting close to needing re-adjusting.
FWIW, it was holding fine when I backed it out of the driveway, and it held in the parking lot where we Peer got behind the wheel (which had at least
as much slope as my driveway).
If the parking pawl is damaged, it is just one of those things that was bound to happen. He was in no way abusive when we parked. I thought he was
being TOO careful when he was moving the lever to P. So no harm, no foul.
Like I said, next time I drive it I will do what I have done with every American car of that era and see if it goes into Park. If it doesn't, I will
fiddle with the adjustment. If that doesn't work, it goes to sleep with the fishes.
Upper Alabama
Mark,
> I thought he was being TOO careful when he was moving the lever to P. >
First time someone called me too sensitive :D
Best regards
Peer Oliver Schmidt
I wasn't being accusatory here. Plenty of opportunities abound in the last
40 years for previous owners to have done too many stupid things to blame
any of the current crew for much of anything. Just mentioned it for the
benefit of the new and next to be new crews out there.
On Apr 12, 2017 9:44 AM, "Peer Oliver Schmidt GMC"
wrote:
> Mark,
> Best regards
> Peer Oliver Schmidt
There is a rod that is attached to the lever on the trans. There is a
sliding barrel with bolt where you can slide it in the rod to adjust.
The bolt can loosen up a little and not allow the lever to be pulled enough
to ge into park.
> > Mark,
> > Best regards
> > Peer Oliver Schmidt
Applied/GMC, Fremont,CA
just a question, if the pawl is damaged is it hard to replace? on Ford trannies I've seen you can get at it from the pan and its pretty simple to
swap. ae GM trannies similar?
As always,what Chuck said is correct. However, it is possible to adjust the barrelslider/rod too far in the direction of PARK and lose the ability to
manually shift into LOW.
Depending on how worn and loose the internal part is, you may have to fiddle with it. Not a big deal- just have a little patience and adjust it so
both gears can be selected.
Gene Barrow
Lake Almanor, Ca.
1976 Palm Beach
Just a little extra info on the internals at play here - the manual lever does not engage the pawl directly, it spring loads the pawl to go into the
next available slot in the drum.
Wanting a GMC but must convince the wife first...
