I ran into that a few years ago with ball joints and posted my findings.
http://www.gmcmhphotos.com/photos/ball-joint-compare/p39635-dsc02815.html
I got no experience with leaving break in oil to many years. I did use Joe Gibbs break in oil and ran it about 1500 miles before changing with no
evident issues.
> After about 500 miles (and too many years) I changed the break in engine oil. There was some metallic grit on the drain plug magnet but none on
> the oil filter medium. Compression in all cylinders was 160 +/- 2 psi.
> WIth the coach front end jacked up and the wheels off for mechanical inspection I decided to lube the front end. On the driver side lower ball
> joint it was necessary to firmly hold the grease nozzle onto the zerk fitting or grease would squirt out from the side of the nozzle. The passenger
> side lower ball joint was completely blocked and could not be greased at all. I removed the zerk fitting and it checked out OK. Then I removed the
> base to the zerk fitting and inside the ball joint could see a circular impression where the base fitting had bottomed out in the grease channel.
> Using a diamond blade on a dremel tool I cut notches in the base threads. That solved the problem and I can now easily lube the lower ball joints.
> These Moog ball joints were installed new a few years back. If I had inspected more carefully the first lube job the blobs of grease around the
> zerk fittings would have been obvious. Fortunately the ball joints don't have too many miles.
> JP
C. Boyd
76 Crestmont
East Tennessee
evident issues.
> JP
C. Boyd
76 Crestmont
East Tennessee
