plan B. I really don't need my ride height sensors/valves anyway. Just simple.
Bob Dunahugh
2,784
4
3
I always have my bags turned off by the isolation valves when on the road. I just need to slightly tilt the drive in shower floor to drain. So two compressors, and 2 solenoid valves to low. Bob Dunahugh 78 Royale
Read here http://bdub.net/gmcmotorhome.info/wireless.html
You are here,sell the leftover parts and be normal.
Alternator Protection Cable
man you like to spam that thing don't you?
Sent: Monday, July 3, 2017 7:22:28 AM
Subject: Re: [GMCnet] plan B. I really don't need my ride height sensors/valves anyway. Just simple.
WHAT DO you mean?
> From: Gmclist on behalf of gene Fisher <
> mr.erfisher>
> To: gmclist
> So
So my understanding of the wireless airbag control is that it will maintain the pressure in the airbags to within +/- 3 psi of the set-point. So you
set your height, then stop and take on a load of fuel, the pressure increases in the bags, so the controller will dump some air to maintain the
pressure.. and the coach drops in height.
Or you are going around a long curve at highway speed, coach tilts to one side causing air pressure to increase on one bag and decrease on the
other... Controller corrects this....which causes the coach to lean the outside even more.
What am I missing here?
Just my farm-boy mechanic way of see things.
Bruce Hislop
ON Canada
Hubler 1 ton front end
Bruce, I do have a dog in this hunt, as I make, install, service, and sell
wireless air systems. To test your beliefs, on a coach, find a couple of
250 pound guys to stand on the rear bumper with the key on. For a minute or
two. See what happens. That is 500 pounds on the end of a long lever. More
effect than a fill up of gasoline. Then report back.
Salem, Or
78 GMC ROYALE 403
outside even more.
Bruce Hislop
ON Canada
I have to run with my 4 Quad bags isolated from each other all the time in case I have a bag go down. Or a failure in the system. So a wireless system can't really be used for me on the road. If I replace my compressors, and down solenoids. That will solve my camp sight issues. Bb Dunahugh
Sent: Monday, July 3, 2017 12:14 AM
Subject: plan B. I really don't need my ride height sensors/valves anyway. Just simple.
Shutoff valves are great safety feature, but have you seen the damage done
by a blown bag ? Would not want my head or hand in there
> From: Bob Dunahugh
> To: gmclist
> Just simple.
> Jim Hupy
Jim,
OK, I don't understand how the wireless system works. Since you "make, install, service, and sell wireless air systems", can you explain or give me a
link for an explanation of how it works as compared to OEM?
Thanks,
Richard
SE Michigan
www.PalmBeachGMC.com
Coop Roller Cam 455, Howell TBI + EBL, 3.42 FD, Quadra Bag, Macerator, Manny Tranny etc.
The wireless system has no ride height sensors, instead relying upon air
pressure monitoring in the bags. Plus or minus 3 psi. The remote control
and the air manifold each have wireless modems that communicate constantly
as long as the ignition key is in "on" or "acc" position. The user selects
the air pressure required to achieve correct ride height, and programs the
remote to reflect that pressure. That stores data in the remote. If the
bags gain or lose as little as 3 psi., the manifold responds by either
starting the built in ViAir 480 compressor and inflating the bags to preset
levels, or by releasing air through a exhaust port in the manifold until
preset pressure is achieved. There are two user selected presettings. One
for ride height, and one for lowering the rear of the coach to drain the
holding tanks. User can override all presettings for campsite leveling.
When ready to leave, all that needs to be done is to push the preset
button, and normal ride height is restored. If your coach is overloaded for
short periods, additional pressure can be added to both sides at the same
time in 10 psi steps with the push of a button as well.
THE ORIGINAL SYSTEMS ALL USE A TIME DELAY TO RESPOND TO WEIGHT
TRANSFER AND ROAD CONDITIONS, SOME AS LONG AS 30 SECONDS. But all things
said, they have a huge "null" point in their sensors. 5/8" in some cases.
So they miss a bunch of conditions that don't last that long.
Salem, Or
78 GMC ROYALE 403
> sell
> or
> More
> > Jim Hupy
> Jim,
> me a
> Thanks,
> Richard
> 76 Palm Beach
> SE Michigan
> Manny Tranny etc.
> Bruce, I do have a dog in this hunt, as I make, install, service, and sell wireless air systems. To test your beliefs, on a coach, find a couple
> of 250 pound guys to stand on the rear bumper with the key on. For a minute or two. See what happens. That is 500 pounds on the end of a long lever.
> More effect than a fill up of gasoline. Then report back.
> Jim Hupy
Jim,
Interesting that you use this as an example.
If I take on fuel and leave the auxiliary electrics powered up, at some time during fueling the suspension compressor will probably start. If I leave
it off, as soon as we power up to pull off the pump, the compressor will start.
If we are stopped, like waiting for a train (a common event here) and one of us gets up and walks to the back, the compressor will probably start.
I am certain that much of this is due to the fact that Chaumière is a 9500# coach and not a 12000# coach that so many are.
I don't have wireless air, but I have the same setup. Dual needle gauge in the dash and push buttons to add and remove air.
I thought at the time it would work fine.
Tomorrow I'm installing new auto valves into the system.
Weight differences, road conditions, WIND, etc all effect the height of the coach.
Will the wireless air work? Sure. Is it ideal? No. The height valves are a real asset here IMHO. (Having done both)
Justin Brady
http://www.thegmcrv.com/
1976 Palm Beach 455
Well help me along here. When you make a long right turn, what do the pressures do? Having driven both of min e with the bags shut off due to leaks,
I like the way they drive when the system is working properly, and the bubble in my inclinometer wanders around the middle as opposed to favoring one
side or the other when things aren't flat.
--johnny
Braselton, Ga.
Making a long right turn the driver bag pressure will increase due to weight transfer, the passenger bag pressure will decrease for the same reason.
With my setup, nothing happens here other that the coach leans because it doesn't "auto correct"
The wireless system in theory will add air to the driver bag and pull air out of the passenger bag making the lean worse than before. Now whether or
not this would be noticeable I can't tell you.
This is the primary reason I didn't do the wireless setup, that and I have never had much luck with airlift's chinese parts.
Just my opinions, not meant to anger anyone.
IMHO the wireless system (and my initial setup) relies on the wrong parameter. The PSI of the bag is irrelevant, the height of each side of the coach
is the relevant factor.
Justin Brady
1976 Palm Beach 455
Pressures don't do anything that I can tell. But, I have a late 78 Royale.
Earlier coaches may do something. I have recently replaced my shocks,
KYB's, and rebuilt the front suspension. Control arms have urethane lower
bushings, as well as forward upper control arms. The eccentric rear uppers
are not urethane, but are new. I6" Eagle alloy hub centric wheels along
with B.F. Goodrich tires load range E. 60 psi in the front, 55 in the rear
4. My coach runs light compared to some. No wig wag or rut wander to speak
of, but, cross winds will affect it. If I ever get caught up with
customer's coaches, I will finish my suspension upgrades. 1 ton up front. 6
wheel disc brakes, Quadra bags, and sway bar reaction arms in the rear.
That ought to remedy the cross wind effects as well as improve the brakes.
Ah well, they are never done, are they?
Salem, Or
78 GMC ROYALE 403
On Jul 3, 2017 1:22 PM, "Johnny Bridges via Gmclist" <
> leaks,
> one
> --johnny
> Braselton, Ga.
When your ride height sensors dictate that your ride height is low, or
high, WHAT CORRECTIVE ACTION MITIGATES THAT? Could it be, that it adds air
pressure to the bags, or lets a bit out? And, how quickly does it react to
do that? Half a minute or so, maybe? Just wondering.
Salem, Or
78 GMC ROYALE 403
Salem, Or
78 GMC ROYALE 403
> leaks,
> one
> --johnny
> Braselton, Ga.
Now you've added another parameter. I put reaction arms on both coaches and was/am greatly impressed with the better stopping distance. I drve a
couach with discs on the back and could tell no difference, so I skipped them. Both have sway bars, but they're normal ones. What's a 'reaction arm
sway bar' please?
--johnny
Braselton, Ga.
Johnny, some reaction arm brakes have their terminal point at the bogie
boxes. There is another version that terminates onto a torsion bar
(sway bar) that mounts on the frame and crosses under the coach to the
bogie on the other side of the coach. There are two bars fitted, one for
the forward bogie, and one for the rear bogie. They are dual purpose.
Reaction arms for the brakes, and sway bars for the rear. Some owners don't
like rear sway bars, some do. I think that they stiffen up the ride a bit,
but improve the handling in crosswinds, which is a problem in the wide open
spaces in the West.
Salem, Or
78 GMC ROYALE 403
On Jul 3, 2017 6:06 PM, "Johnny Bridges via Gmclist" <
> sway bar' please?
> --johnny
> Braselton, Ga.
G'day,
Regarding the time delay for the Power-Level system see:
MM X-7525 / Section 4 - Rear Suspension / Pages 4-25 & 4-26 - TIME DELAY CHECK
The Electro-Level system uses the same height control valves therefore the delay is the same.
For Electro-Level II see:
MM X-77725 / Section 4 - Rear Suspension / Pages 4B-3, 4B-4 & 4B-5 ELECTRONIC HEIGHT SENSOR
Regards,
Rob M.
Sydney, Australia
-----Original Message-----
From: Gmclist [mailto:gmclist-bounces] On Behalf Of James Hupy
Sent: Tuesday, July 4, 2017 6:51 AM
Salem, Or
78 GMC ROYALE 403
Salem, Or
78 GMC ROYALE 403
> leaks,
> one
> --johnny
> Braselton, Ga.
Thanks, hadn't seen that setup. Both of mine were already fitted with sway bars when I got them. Maybe someone with this setup will be at the
eclipse party and I can get a look.
--johnny
Braselton, Ga.
