https://www.gmcrvparts.com/category-s/154.htm
On Wed, Jul 17, 2019 at 5:22 AM Todd Snyder via Gmclist <
> Just to follow up on my original question about the factory puller setup.
> I bought a pair of puller fingers specified in the GMC maintenance manual,
> they look kind of like paddles on one end. Got the GM spec'd puller as
> well. Both were on ebay.
> Following the procedure in the manual, I pulled the hub assembly with a
> slide hammer and then attempted to pull the bearings from the hub with the
> GM
> specified puller setup.
> 1st set, I kept missing the inner race on one side, pulled on the cage and
> ended up bending it, ruined bearing. Once that was moved a little though,
> I could catch the tiny lip of the inner race and pull it. There was not
> much there to catch, like maybe 1/16th inch of a ridge. They were bower
> bearings, grease looked pretty tired, probably due for changing anyway
> since the previous owner said he knew nothing about changing or greasing any
> front wheel bearings.
> 2nd set, I realized that what that puller needed was a BFH. Couple whacks
> downward on the individual paddles and I was able to push the grease seal
> out of the way enough catch the lip on both sides. Bolted on the puller,
> C-clamped it to keep the paddles from spreading as shown in the service
> manual, hit it with the impact gun and the bearing practically flew off
> unharmed. Bet it didn't take more than 5 minutes total from me walking
> into
> the garage to having the bearing in my hand.
> So the answer is, yes, they work quite well once the grease seal is pushed
> firmly (read BFH) out of the way.
> Todd Snyder, Buffalo NY
> 1976 Eleganza II
