Original GM bearing puller tool
tmsnyder
3,351
1,241
113
Buffalo NY
I've been searching online but can't seem to find any reference to the original GMC specified front wheel bearing puller being used on our motorhomes.
Does anyone use one? Any first hand experience on how well does it work, instructions?
Todd Snyder, Buffalo NY
1976 Eleganza II
Go to our web site ad look at few of the ones people have done for us that
is similer to the origional.
What is important is that it an grab the inner race and fit past the rotor.
Should you want to make one and need some measurements, call me and I will
do it.
On Mon, Jun 24, 2019 at 10:23 AM Todd Snyder via Gmclist <
> motorhomes.
> instructions?
> 1976 Eleganza II
http://www.appliedgmc.com
Original GM specified puller came in the mail yesterday, it's pretty nice, can't wait to try it but I need to make a little hockey puck for the puller
to push upon. Can anyone confirm that the ID of the stock bearings are 1.875"?
1976 Eleganza II
If you are going through the trouble of taking the hubs apart to regrease the bearings, and if the hubs are ok, take the time to get ahold of the dirk
drilling tool and drill the knuckle for the zirk. You will also need to drill or grind the bearing spacer between the two bearings to allow for grease
to flow from the dirk to the bearings. See the link below for how to use the tool. Service interval calls for regreasing the bearings every 25K miles.
Problem is every time you remove the bearings, you do a little more damage to the knuckle, and eventually the bearing races become so loose that they
can spin in the knuckle potentially leading to bearing failure. By drilling for the zirk, you will be able to regrease the bearings without (in your
lifetime) ever having to remove the knuckles/bearings again. You would simply then have to lift the coach, remove the axle nut from the axle shaft,
tap the axle shaft in, and then apply grease to the fitting. By pushing the axle shaft in, the inner seal will no longer be in contact with the seal
surface and grease will flow freely. So you flow grease until you see clean grease come out of the seal area. If you do not tap the axle in, the
hydraulic pressure of the grease will push the seal out of position, and it will no longer seal from dirt and water. HTH
http://www.gmcmhphotos.com/photos/front-bearing-drill-fixture/p33853-front-wheel-bearing-drill-fixture.html
Larry
78 Royale w/500 Caddy
Menomonie, WI.
Just to follow up on my original question about the factory puller setup. I bought a pair of puller fingers specified in the GMC maintenance manual,
they look kind of like paddles on one end. Got the GM spec'd puller as well. Both were on ebay.
Following the procedure in the manual, I pulled the hub assembly with a slide hammer and then attempted to pull the bearings from the hub with the GM
specified puller setup.
1st set, I kept missing the inner race on one side, pulled on the cage and ended up bending it, ruined bearing. Once that was moved a little though,
I could catch the tiny lip of the inner race and pull it. There was not much there to catch, like maybe 1/16th inch of a ridge. They were bower
bearings, grease looked pretty tired, probably due for changing anyway since the previous owner said he knew nothing about changing or greasing any
front wheel bearings.
2nd set, I realized that what that puller needed was a BFH. Couple whacks downward on the individual paddles and I was able to push the grease seal
out of the way enough catch the lip on both sides. Bolted on the puller, C-clamped it to keep the paddles from spreading as shown in the service
manual, hit it with the impact gun and the bearing practically flew off unharmed. Bet it didn't take more than 5 minutes total from me walking into
the garage to having the bearing in my hand.
So the answer is, yes, they work quite well once the grease seal is pushed firmly (read BFH) out of the way.
1976 Eleganza II
https://www.gmcrvparts.com/category-s/154.htm
On Wed, Jul 17, 2019 at 5:22 AM Todd Snyder via Gmclist <
> GM
> into
> 1976 Eleganza II
