>What I did was remove the front fly wheel and the sheet
>metal cover behind it. ....
**-> !!Major caveat!! HAS ANYONE EVER REMOVED THE REAR GENERATOR SECTION FROM THE ENGINE? ARE
>THERE ANY TRICKS OR WATCH OUT FORS BEFORE I REMOVE THIS SUCKER?
Its actually not that hard. I replaced the bearing and commutator on mine
when one of the commutator wires burned up. Its been a while but I think
there are just the four bolts holding the stator and a bolt holding the
shaft to the bearing. Be careful with the weight. The back half weighs as
much or more than the front half. Be sure that they are both well
supported. I don't recall any major problems getting it apart. Of course
replacing the commutator rings is a whole nuther story!
Given that its so much easier to work on when its out of the coach, it
would probably be a good idea to check the brushes and replace them if they
look worn.
If you do decide to take it apart, I would consider replacing the rear
bearing too.
Dave
73 Sequoia
look worn.
bearing too.
Dave
73 Sequoia
