As soon as you start to crank the ONAN, the solenoid fuel shut off makes
one "click" and then the resulting output voltage at the control board
provides the 12 volt D.C. for it to remain pulled. When the Onan is turned
off, no 12 volts D.C on the board, and the solenoid plunger retracts,
making another "click". Usually so much noise associated with starter and
related stuff, that those clicks are hard to hear. Easier to hold on to the
thing and feel them, than to hear them.
> Yeah, still poking away at the generator in between other jobs. Anyhow,
> while cranking it over found out it also needs a muffler.
> Good point about the fuel level. I'll probably leave it until I get more
> fuel, it's a backburner project anyway.
> What I would like to know if what is the normal sounds to hear when
> priming the system? I got the fuel pump thumping/ticking, but never
> felt/heard
> the solenoid valve click. Is the pump supposed to stop thumping once it
> reaches pressure?
> > Still on the Onan gas line. Just for grins and giggles, blow some air
> back
> > through your new hose, just to verify that you actually have a fuel level
> > high enough in the rear tank to cover up the end of the hose. The pump
> will
> > not account for a low fuel level in the tank. I don't care what your gage
> > says.
> > Jim Hupy
> > Salem, Oregon
> > >> If the H4 Amp draw is much higher than stock, lights may start to
> cycle
> > > off after a while when the dash breaker switch starts to do it’s
> job. I
> > >> say this because you don’t mention a relay loom kit.
> > > I just have regular bulbs in there, I think 55 watt.
> > > Burl Vibert
> > > Kingston, Ontario
> > > 1976 GMC 26 foot, don't know the model
> > > _______________________________________________
> > > GMCnet mailing list
> > > Unsubscribe or Change List Options:
> Burl Vibert
> Kingston, Ontario
> felt/heard
> reaches pressure?
> back
> will
> > says.
> > Jim Hupy
> > Salem, Oregon
> cycle
> job. I
> > > Burl Vibert
> > > Kingston, Ontario
> > > GMCnet mailing list
> Burl Vibert
> Kingston, Ontario
